[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Jun 9 06:39:43 PDT 2011
On 09/06/11 12:53, Sandro Santilli wrote:
> Every new release in the 3.x.x series is backward compatible at the C-API
> level. PostGIS uses the C-API.
True. Plus new GEOS releases are invariably better (read as: more
robust) than their predecessors, so if you can go for this option I
would definitely recommend it.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
