[postgis-users] Interpolation problem
Chris Hermansen chris.hermansen at tecogroup.ca
Tue Jun 21 21:05:05 PDT 2011
What are the three measurements?  Is it reasonable to assume that knowing
three measurement values tells you the location ie is there a unique x,y for
each triple of measurements?
On 2011-06-21 8:54 PM, "Saka Royban" <sakaroyban at yahoo.com> wrote:
> Hi all
> I'm not sure whether this can be done completely via PostGIS or it needs
some
> programming. Anyway, at this step no problem with programming if Knowing
the way
> and algorithm.
> I have point shapefile (arranged like a grid) and for each point there is
3
> similar measurements (obtained via 3 transmitters) and, of course, x and y
> coordinates. The problem is that when i have a new point with these 3
measures,
> How can i interpolate its coordinates and specify its location?
> Maybe helpful to say, this type of measurement is distance dependent but
> unfortunately i don't know the exact formula.
> Any help would be appreciated.
> Best Regards
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110621/365bbf33/attachment.html>
