[postgis-users] Failed POST GIS on Re-boot.
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jun 24 01:57:28 PDT 2011
On 23/06/11 20:25, Chris Seker wrote:
> Hi all.  I am running PostgreSQL 9.1 and PostGIS2.0 under CENTOS.  After
> install, the server worked fine and we spent about 2 weeks building
> databases, etc. Then after some routine hardware maintenance and
> re-boot, we get the following error.
> Top of Form
> *SQL **select * from "oxbuildings2" limit 25 offset 0** failed :
> **ERROR: could not load library "/usr/pgsql-9.1/lib/postgis-1.5.so":
> /usr/pgsql-9.1/lib/postgis-1.5.so: undefined symbol: pj_set_searchpath ***
> Bottom of Form
> Anyone have an idea? I am thinking that it’s a simple ENV setting.
pj_set_searchpath() was something that didn't exist in the really early
versions of PROJ.4 - is there a chance you could have accidentally
downgraded your version of PROJ.4? What does 'proj -v' show?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
