[postgis-users] Fwd: Live records and number of records are differents...
Nicolas Ribot nicolas.ribot at gmail.com
Tue Jun 28 02:33:27 PDT 2011
> Hello list,
> I use PostgreSQL 8.4 and Postgis 1.4.
> I use FME to insert 772185 records in a table (multipolygons that represent
> parcels).
> Everything seems fine but...
> If I type select count(*), I get the right number of records : 772185
> records.
> But If I use pgAdmin and have a look in the stats :
> - row inserted = 772185 OK fine,
> - but the number of live rows is 772308...
> I don't understand why the number of live rows and the number of rows is
> différent...
> Any explaination would be very appreciated !
> Thanks you
Hi, it probably means the table statistics should be updated.
try:  vacuum analyse <table>
Nicolas
