[postgis-users] simple question about views and tables
Robert Buckley robertdbuckley at yahoo.com
Wed Jun 29 13:05:22 PDT 2011
I have a table called "windturbines".
I have created a view called "v_sum_yield".
I would now like to either create another view which consists of both tables
joined with the column "bez", or join the view to the original table.
The table comprises of single wind turbines and their yield per year. I need to
sum the yields according to the region. This table then needs to be served as
wfs/wms through geoserver.
my first step was...
CREATE VIEW v_sum_yield AS
select region, sum(yield) AS result
from windturbines
group by region
and then to create another view comprising of an left outer join to the original
table...
CREATE VIEW v_join AS
SELECT *
    FROM windturbines LEFT OUTER JOIN v_sum_yield ON (windturbines.region =
v_sum_yield.region);
the result is..
ERROR: column "region" specified more than onceSQL Status:42701
however if I just run the selection with the "CREATE VIEW v_join AS"...it works
fine.
can anyone tell me why?
thanks,
Rob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110629/2220e575/attachment.html>
