[postgis-users] Illegal Byte Sequence
Andreas Forø Tollefsen andreasft at gmail.com
Mon Mar 14 03:31:09 PDT 2011
Great.
Yes, I am running the trunk version.
Thank you Nicklas for this information.
Andreas
2011/3/14 Nicklas Avén <nicklas.aven at jordogskog.no>
> Hallo Andreas
> May I guess you are running the trunk version.
> I think it is related to tichet #808
> http://trac.osgeo.org/postgis/ticket/808
> One workaround is described in the ticket by creating the .sql file
> without any encoding parameters and then change the first row of the sql
> file to
> SET CLIENT_ENCODING TO LATIN1;
> before running it in psql
> Another workaround is using an older skp2pgsql to create the sql-file.
> PostGIS will load it in PostGIS 2 format anyway.
> HTH
> Nicklas
> On Mon, 2011-03-14 at 11:11 +0100, Andreas Forø Tollefsen wrote:
> > The error:
> > Importing shapefile (1267 records)...
> > Unable to convert data value to UTF-8 (iconv reports "Illegal byte
> > sequence"). Current encoding is "UTF-8". Try "LATIN1" (Western
> > European), or one of the values described at
> > http://www.postgresql.org/docs/current/static/multibyte.html.
> > Shapefile import failed.
> > 2011/3/14 Andreas Forø Tollefsen <andreasft at gmail.com>
> >         Hi,
> >         I am trying to import this shapefile into a database on my new
> >         server:
> http://sedac.ciesin.columbia.edu/povmap/downloads/ds_global/imr_shapefile.zip
> >         While this was no problem on my old server running Windows
> >         Vista, i now have problems on my Ubuntu Server.
> >         My last server had the LC_COLLATE AND LC_CTYPE blank, while
> >         the new Linux has en_US.UTF-8 which seems to create the
> >         problems.
> >         I tried creating a new database on the new server with blank
> >         COLLATE and CTYPE, but it would not accept blank.
> >         Any ideas?
> >         Thanks,
> >         Andreas
> >         The old database had the following settings on Enconding:
> >         CREATE DATABASE newpg
> >           WITH OWNER = -----
> >                ENCODING = 'UTF8'
> >                TABLESPACE = pg_default
> >                LC_COLLATE = ''
> >                LC_CTYPE = ''
> >                CONNECTION LIMIT = -1;
> >         The database on the new server has the following:
> >         CREATE DATABASE priogrid
> >           WITH OWNER = -----
> >                ENCODING = 'UTF8'
> >                LC_COLLATE = 'en_US.UTF-8'
> >                LC_CTYPE = 'en_US.UTF-8'
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110314/a2e4ffb5/attachment.html>
