[postgis-users] postgis raster : getting pixel value
Ackbar Joolia ackbar at ackadij.com
Tue Mar 15 04:55:06 PDT 2011
Hi Jorge,
My geom table is of type MultiPolygon - I don't see where else a
MultiPolygonE type would be coming from.
2011/3/15 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> On Tue, Mar 15, 2011 at 11:36 AM, AJ7 <ackbar at ackadij.com> wrote:
> > Jorge Arévalo-2 wrote:
> >> Hello,
> >> This error is probably caused because last PostGIS version from trunk
> >> uses a modern version of GEOS library. Could you update your GEOS
> >> version?
> > Hi Jorge,
> > I am using postgis 1.5.2-2 (from Kyngchaos), and My GEOS version is
> 3.2.2-1
> > View this message in context:
> http://old.nabble.com/postgis-raster-%3A-getting-pixel-value-tp31146394p31152534.html
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Mmmm... I'm using GEOS 3.3. Looking at the code (I've tried to
> download GEOS 3.2.2 sources but download.osgeo.org looks down), I see
> that exception is thrown when constructing a Geometry object and you
> add a object different from Point, LineString, Polygon or
> GeometryCollection. The type " N4geos4geom12MultiPolygonE" looks
> weird. I guess only the last part is taken into account
> (MultiPolygonE). Does it exist?
> I don't know if it helps. I've not used KingChaos packages.
> Jorge Arévalo
> Internet & Mobilty Division, DEIMOS
> http://es.linkedin.com/in/jorgearevalo80
> http://mobility.grupodeimos.com/
> http://gis4free.wordpress.com
> http://geohash.org/ezjqgrgzz0g
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110315/5b5031a8/attachment.html>
