[postgis-users] PostGIS Raster Decimal?
Andreas Forø Tollefsen andreasft at gmail.com
Wed Mar 16 06:24:34 PDT 2011
Is the above memory issue known for the ST_MapAlgebra function?
Did you experience this Regina?
I will try with some other rasters.
The WARNING lines are just a sample. I think it went through a couple of
thousands before it ran out of memory.
Is it not strange that the truncated values are the same as the original
values?
Andreas
2011/3/15 Andreas Forø Tollefsen <andreasft at gmail.com>
> Hi Pierre,
> I got memory issues as well.
> I tried with this query:
> SELECT ST_MapAlgebra(rast, 'rast*10') INTO algtest FROM gpw90;
> WARNING:  Pixel value for 32BF band got truncated from 47519.1 to 47519.1
> WARNING:  Pixel value for 32BF band got truncated from 185494 to 185494
> WARNING:  Pixel value for 32BF band got truncated from 28485.1 to 28485.1
> WARNING:  Pixel value for 32BF band got truncated from 10927.1 to 10927.1
> ERROR:  out of memory
> DETAIL:  Failed on request of size 19.
> ********** Error **********
> SQL state: 53200
> Detail: Failed on request of size 19.
> 2011/3/14 Paragon Corporation <lr at pcorp.us>
>>  Pierre,
>> Actually the single raster version is documented.  Though I did run into
>> memory issues -- so still think we need some work on that.
>> http://www.postgis.org/documentation/manual-svn/RT_ST_MapAlgebra.html
>> Regina
>> http://www.postgis.us
>> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
>> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Andreas
>> Forø Tollefsen
>> *Sent:* Monday, March 14, 2011 2:03 PM
>> *To:* PostGIS Users Discussion
>> *Cc:* Pierre Racine
>> *Subject:* Re: [postgis-users] PostGIS Raster Decimal?
>> Hi Pierre,
>> I will check it out tomorrow and give some feedback.
>> Cheers,
>> Andreas
>> 2011/3/14 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
>>>  I’m very aware of the problem. Will try to fix it the best we can.
>>> Why not testing ST_MapAlgebra and give us your feedback? It is still to
>>> document but the specifications are in this page:
>>> http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking02
>>> Pierre
>>> Forø Tollefsen
>>> *Sent:* 14 mars 2011 11:24
>>> Hi Pierre.
>>> Yes. I think that would be an appropriate temporary fix.
>>> Still, a bit problematic when working with climate data which very often
>>> include decimal digits and often have weekly and monthly rasters for 100's
>>> of years :)
>>> Good luck.
>>> Best,
>>> Andreas
>>> Andreas,
>>> This is a well known problem. See ticket
>>> http://trac.osgeo.org/postgis/ticket/650
>>> I will discuss this problem with Frank this week at the code sprint in
>>> Montreal.
>>> For now you can use some GIS with map algebra capability to multiply your
>>> raster by 10 before importing or test our brand new ST_MapAlgebra function
>>> (still to debug).
>>> Pierre
>>> >-----Original Message-----
>>> >From: Pierre Racine
>>> >Sent: 14 mars 2011 10:55
>>> >To: Pierre Racine
>>> >Subject: FW: [postgis-users] PostGIS Raster Decimal?
>>> >From: postgis-users-bounces at postgis.refractions.net [mailto:
>>> postgis-users-
>>> >bounces at postgis.refractions.net] On Behalf Of Andreas Forø Tollefsen
>>> >Sent: 14 mars 2011 10:53
>>> >To: PostGIS Users Discussion
>>> >Subject: [postgis-users] PostGIS Raster Decimal?
>>> >Hi. Again.
>>> >I have been working on some raster data in PostGIS lately.
>>> >However, i have some issues with the raster values become integer after
>>> importing the sql to postgis.
>>> >For instance this procedure:
>>> >C:\prio_grid\source\gpw>c:\python26\python
>>> c:\prio_grid\script\raster2pgsql.py -
>>> >r c:\prio_grid\source\gpw\lrc30p90\glp90ag30\w001001.adf -t gpw90 -s
>>> 4326 -o gpw
>>> >90.sql -I -M
>>> >Then to database:
>>> >C:\prio_grid\source\gpw>psql -h 192.168.1.55 -d priogrid -f gpw90.sql
>>> >Querying this data:
>>> >SELECT gpw90.gid, ((gpw90.gpw90val).val) AS gpw90
>>> >INTO popgrid
>>> >FROM (SELECT priogrid_land.gid, ST_Intersection(gpw90.rast,
>>> priogrid_land.centroid) AS gpw90val FROM
>>> >gpw90, priogrid_land WHERE ST_Intersects(priogrid_land.centroid,
>>> gpw90.rast)) AS gpw90
>>> >WHERE gpw90.gid = 139303
>>> >GROUP BY gid,((gpw90.gpw90val))
>>> >Gives:
>>> >gid; gpw90
>>> >139303;39849
>>> >The value in the original raster is:
>>> >39849.2
>>> >Question is then. How can i ensure that raster remain decimal and not
>>> integer after this import and
>>> >query process?
>>> >Thanks.
>>> >Andreas
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110316/3a1d1400/attachment.html>
