[postgis-users] drawing nautical data on projection 4326[solution?]
Dave dave.potts at pinan.co.uk
Sun May 1 03:24:41 PDT 2011
On 29/04/2011 13:22, Morin, Marc-André wrote:
Hi Marc,
Thanks for the advice,  I had choosen to use 4326 mainly because its the
default in postgis for so many calls.
I shall just convert my data to 900913/3857 and forget having to convert
anything on the fly.
> Hi Dave,
> You are certainly not on the right track, because the SRS EPSG:4326 is
> not a projection system, but more a datum (WGS84), based on an
> ellipsoid (GRS80).  In a nutshell, the 4326 srs is a "spherical"
> geographic system and that is why the unit of measurement is in
> degree.  So when you store your data in EPSG:4326, that means your
> data will have to be stored in latitude and longitude, and you cannot
> represent lat-long coordinates directly on a map, unless these
> coordinates are projected in a cartesian (X and Y) coordinate system,
> like the Google Mercator projection (EPSG:900913).
> That said, you specified in your first mail that your were working
> with "lines" measured in nautilcal miles, within a grid graduated for
> 0 to 100.  That means that you are already in a "projected" coordinate
> system.   Now, we have to figure out what is this coordinate
> system. Maybe I am wrong, but your 0-100 grid seems to represent a
> cartesian coordinate system in GRAD (not in degree)...
> Could you check and confirm that at first?  Also, a screenshot of your
> map would be helpful...
> Regards,
> Marc-André
> *De :* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *De la part de*
> Dave
> *Envoyé :* 29 avril 2011 04:05
> *À :* PostGIS Users Discussion
> *Objet :* Re: [postgis-users] drawing nautical data on projection
> 4326[solution?]
> I think I have a solution to this issue
> I am going to convert my point origin to meter based projection (eg
> google 900913), create my line data, then transform it back to the
> 4326 projection,  in this way the scale factors calculations should be
> done by the proj library.
> Does this sound like a decent solution?
> On 28/04/2011 10:48, Dave wrote:
>> I have some line  data measured in nautical miles.
>> I want to draw these points on a map using the 4326 projection, the
>> srs entry for this projection gives the unit of measurement as degree.
>> A nautical mile is one minture of an arc of lattitude ie 0-60, the
>> projection is measured in 0-100.
>> So does this mean that when I want to draw a line measured in
>> nautical miles,  I have map 0-60 on to 0-100 grid , ie I have to
>> apply  0.6 factor ?
>> So a line  starting at lat 1.2 and ending at  lat 2.7 becomes a line
>> 1.12  to  2.42 ?
>> regards
>> Dave.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110501/72706dfa/attachment.html>
