[postgis-users] Geocoder (from extras)
Dan Putler dan.putler at sauder.ubc.ca
Sat May 7 16:38:17 PDT 2011
Hi Johnathan,
Yes it is. The web site is drastic need of updating, but development is
on going. Recent development has been on expanding the set of data
stores. As Steve indicates, we have added SQLite, and are working on
including Postgres.
Dan
On 05/07/2011 04:29 PM, Johnathan Leppert wrote:
> Do you know what the status of the PAGC project is? Is it still under
> active development? The last post was in 2008.
> On Sat, May 7, 2011 at 5:00 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Stephen,
>     In a geocoder I wrote in 2000, I mapped city, state and/or zipcode
>     into a list of counties, then only searched those counties. This
>     greatly reduced the 3300 counties in Tiger to a small handful that
>     needed to be searched. The FIPS-4 document has a mapping of all
>     place names to counties. Zipcodes are easier to handle because you
>     can just index the records with zipcodes but if you wanted to
>     widen the search, then map the zipcode to a place name and then to
>     counties.
>     My first thought was to use inherited tables where each state or
>     state equivalent is in a separate table and filter the tables by
>     the state name of abbreviation. It sounds like you might be
>     already doing something like this.
>     I think trigrams would provide some benefits. I have used double
>     metaphone, but only used the first code for fuzzy searches because
>     this is a better phonic search key than soundex in my opinion
>     because it matches thinks that sound alike even if they do not
>     start with the same letter. Since I used it as a key I only used
>     the first 4 characters of the metaphone code.
>     I wrote my own tiger geocoder in C and have since abandoned that
>     in favor of PAGC. PAGC has just recently refactored the code to
>     support SQLite as a datastore and has had some work done to
>     support Postgresql in addition to the previous support for
>     Berkeley DB. One idea that I had was that with appropriate support
>     for database backing stores, that the PAGC library might be able
>     to be wrapped in a stored procedure which would then provide a
>     high quality and high performance geocoder in the database.
>     Here is an instance that I created using SQLite as the backing
>     store and Tiger 2010 data:
>     http://imaptools.com:8080/geocode/
>     The single line parsing is broken at the moment, I have a ticket
>     to look into that and hope to have it resolved shortly.
>     PAGC project can be found here:
>     http://www.pagcgeo.org/
>     Regards,
>      -Steve
>     On 5/6/2011 10:36 PM, Stephen Frost wrote:
>         * Johnathan Leppert (johnathan.leppert at gmail.com
>         <mailto:johnathan.leppert at gmail.com>) wrote:
>             Ok, I have it working, but it's very very slow. It takes
>             about two seconds
>             to geocode a single record. This isn't very realistic for
>             large datasets.
>             Anyone have any ideas on possible optimization? It appears
>             to have created
>             proper indexes on all the tables.
>         Yeah, there's a few things I've been working on.  For one, a
>         lot of the
>         time is spent planning that massive query at the heart of the
>         geocoding,
>         when it really doesn't need to be re-planned for every query.
>          It's done
>         the way it is currently because the tables are partitioned up
>         by state.
>         I've got someone working on simply splitting that query up to
>         be 53 (or
>         however many...) queries, one for each state/territory, which
>         will allow
>         them to be planned once and then the plans re-used inside the same
>         session.  That should improve things.
>         I've also been looking into using trigrams for things instead
>         of the
>         current indexes..  I think they're perform better with regard
>         to speed,
>         just need to make sure it still returns good results, etc..
>         I'm very interested in anyone else working on this and any
>         suggestions
>         people have for how to improve it..  I've not been able to
>         work on it
>         much recently and while I've tried to delegate it to others,
>         it's a
>         pretty complex system which is, in particular, hard to test well..
>                Thanks,
>                        Stephen
>         _______________________________________________
>         postgis-users mailing list
>         postgis-users at postgis.refractions.net
>         <mailto:postgis-users at postgis.refractions.net>
>         http://postgis.refractions.net/mailman/listinfo/postgis-users
> /Johnathan/
> Software Architect & Developer
> Columbus, Ohio
> /Follow me on Twitter: @iamleppert <http://twitter.com/#%21/iamleppert>/
