[postgis-users] gridded data
Stephen Crawford src176 at psu.edu
Mon May 9 09:13:02 PDT 2011
Great info, thanks a lot.
If you think it best to store each weather variable in a separate table,
then I imagine that would be by date too, i.e. a table named
"max_temp_05_09_2011" or something like that?
Thanks,
Steve
On 5/9/2011 11:55 AM, Pierre Racine wrote:
>> I want to use daily weather variables that are in a grid for USA.  I
>> would want store the daily variables ( a new grid each day) so I can
>> have a database that will allow the client to send a point lat/lon and
>> then return a calculation based on a few days worth of two or three
>> variables.
>> Do I store each day (or variable) as a new table?  How does a grid get
>> stored in postgres?  Is this a job for PostGIS Raster (though I do not
>> want to produce images, just queries at a point)?
> Hi Steve,
> PostGIS with the raster extension is just the right tool to do that. I would recommend to store each weather variable in a separate table.
> To tile (with the raster2pgsal.py -k option) or not to tile your rasters depends on their size. Generally it is better to tile them.
> Assuming your rasters are in a geographic coordinate system, you can then query the temperature for a lat/long like this (if they are tiled):
> SELECT ST_Value(rast, ST_MakePoint(lat, long) as temp
> FROM yourrastertable
> WHERE ST_Intersects(rast, ST_MakePoint(lat, long))
> Just omit the WHERE clause if you don't tile them when loading.
> Try also:
> WHERE ST_DWithin(rast, ST_MakePoint(lat, long), 0)
> Which might be faster...
> Please refer to the PostGIS Raster tutorials:
> http://trac.osgeo.org/postgis/wiki/WKTRaster
> Pierre
> postgis-users mailing list
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
src176 at psu.edu
814.865.9905
