[postgis-users] postgis-1.5.2 build failure on HP-UX
Sandro Santilli strk at keybit.net
Tue May 10 08:16:14 PDT 2011
On Tue, May 10, 2011 at 05:02:32PM +0200, Sandro Santilli wrote:
> On Tue, May 10, 2011 at 02:58:07PM +0100, Mark Cave-Ayland wrote:
> > On 06/05/11 17:47, MUHAMMAD ASIF wrote:
> > >`/home/edb/AS90/postgis/postgis-1.5.2/postgis'cc +DD64 -Ae -E
> > >-traditional-cpp postgis.sql.in.c | grep -v '^#'>  postgis.sql.incc: error
> > >1914: bad form for `-t' optionmake[1]: *** [postgis.sql.in] Error
> > >1make[1]: *** Deleting file `postgis.sql.in'make[1]: Leaving directory
> > >To fix it, I just removed the -traditional-cpp option that is related to
> > >GCC. Build seems fine. It can be compiled with non gcc compilers then why
> > >is there option "-traditional-cpp" hard coded related to GCC. Thanks.
> > I think Sandro was the person who did this part of the build system, so
> > perhaps he may know?
> I see that actually -traditional-cpp flag is now handled by configure
> script, so should likely be taken out from out use of it.
> I'll take a look.
So, if I take -traditional-cpp out, I get tons of these:
 warning: missing terminating ' character
Which is basically everytime a line ends before a quote is closed.
That said, it'd surely be better not to use a "C" preprocessor
for something which isn't "C"...
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
