[postgis-users] [postgis-devel] how to keep geometry_columns in sync wit tablesand views (and new PostGIS 2.0 plans)
Paragon Corporation lr at pcorp.us
Sun May 22 09:19:41 PDT 2011
Steve,
* Paragon Corporation (lr at pcorp.us) wrote:
> I would almost go with forcing everyone to change their existing
> tables to typmod if they want to reap the benefits of PostGIS 2.0, but
> most of my clients will not go to 2.0 then.
> What I havn't heard yet is any explanation or description of *why* they
wouldn't want to move to 2.0 if it only supported the typmod approach..?
See my comment in the trac item - (short answer there are some use cases
that just can't be implemented with typmod)
http://trac.osgeo.org/postgis/ticket/944#comment:22
> We could try Mark's idea of hacking the catalog tables to
> automagically convert table constraints to typmod but that all sounds
pretty scary to me.
> The upgrade question should not be terribly difficult to solve by just
using the current geometry_columns table to help with the generation of the
new tables...?
New tables -- oh no, you'd have to do an alter (or as Mark wants directly
update the catalogs)  -- imagine the nightmare if you have foreign key
constraints and what not having to create new tables.
I have no tables to test with since we don't have typmod, but once Paul gets
typmod in there (HINT HINT), I can test with fairly large tables to see how
painful doing an alter and dropping constraints would be.
> Especially with my special
> Inheritcance case -- I can just see that failing miserably and
> screwing up my tables.
> Can you provide more insight on this..?  I'm not familiar with your
'special inheritance case'..
See trac comment.
Thanks,
Regina
http://www.postgis.us
