[postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Paul Ramsey pramsey at opengeo.org
Fri May 27 09:58:16 PDT 2011
On Thu, May 26, 2011 at 11:00 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, May 26, 2011 at 11:46:34AM -0700, Paul Ramsey wrote:
>> Like so?
>> http://trac.osgeo.org/postgis/attachment/ticket/987/inf2.patch
> A few points:
> 1: GEOS-driven ST_IsValid raises a NOTICE containing the reason, home-made
>   version should do the same.
> 2: I see you're not handling nan, just infinite. Is that intentional ?
> 3: GEOS-3.2 also survive the inf/nans in GEOSValid, why checkin for 3.3+ ?
Because the isvalid hooks work in conjunction with the lower hook,
which is filtering at 3.3+. Turning off the isvalid hook at 3.2 just
means you get caught one level deeper. For consistency, having it all
at 3.3 is what's needed.
> 4: Expecting the error in tickets.sql makes the whole test file
>   pass or fail based on the version of GEOS you built postgis against.
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
