[postgis-users] ST_StartPoint fails with MultiLineString
Paul Ramsey pramsey at opengeo.org
Thu Nov 24 07:30:13 PST 2011
It's strictness. Not sure how much I like it, but that's been the
behavior for quite a while.
P.
On Thu, Nov 24, 2011 at 5:39 AM, Jose Carlos Martinez
<jomarlla at cgf.upv.es> wrote:
> HI,
> p2211=# select st_startpoint ('MULTILINESTRING ((0 0, 10 0))');
>  st_startpoint
> (1 row)
> returns null, according to SQL/MM  ST_StartPoint is working with ST_Curve,
>  this is ok.  But I do not think its practical, besides previous versions of
> PostGIS returned the first point correctly.
> Is this a bug or PostGIS is trying to follow standards in a more strict way?
> same with st_endpoint.
> Cheers,
> PD:
> p2211=# select postgis_lib_build_date(), postgis_full_Version();
>  postgis_lib_build_date |
>             postgis_full_version
>  2011-11-22 08:39:41    | POSTGIS="2.0.0SVN" GEOS="3.3.2dev-CAPI-1.7.2"
> PROJ="Rel. 4.6.1, 21 August 2008" GDAL="GDAL 1.9dev, released 2011/01/18"
> LIBXML="2.7.8" USE_STATS
> (1 fila)
> postgis-users mailing list
