[postgis-users] Need Help :How to Install PostGIS Raster
Paragon Corporation lr at pcorp.us
Thu Oct 6 01:30:54 PDT 2011
BTW - just put up a newer version  so if you haven't installed yet, you
might want to redownload again.  It won't solve whatever problems you had
but it has the newest changes as of October 5th and there have been a lot it
seems between 3oth and 5th.
Also has the release 3.3.1 version of GEOS.
Also make sure you are running 32-bit PostgreSQL 9.0.  That is another
common mistake and these are 32-bit binaries so won't work with the 64-bit
PostgreSQL.
Thanks,
Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Jorge Arévalo
> Sent: Thursday, October 06, 2011 4:18 AM
> To: Wendi Adrian; PostGIS Users Discussion
> Subject: Re: [postgis-users] Need Help :How to Install PostGIS Raster
> On Thu, Oct 6, 2011 at 2:55 AM, Wendi Adrian
> <wendiadriansaga at yahoo.com> wrote:
> > Dear all,
> > it is great for me to join with you in PostGIS user milist.
> :) I need
> > your advices, maybe some of you have found same problems with me.
> > I have installed PostgreSQL v.9.0 and want to install PostGIS v.2.0
> > which I have download from Postgis website. The files was
> called postgis-2.0.0 SVN.
> > This supports PostGIS Raster database based on
> documentation I found.
> > I try to install it, but always find errors which can described as
> > follow ;
> > 1) I use command prompt to run makepostgisdb.bat but I adapt
> > environmental variables in windows according to parameters.
> > 2) when I run it, I get notification "operation
> aborted...transaction block"
> > 3) I rename libiconv-2.dll in Postgresql/8.4/bin folder to
> any other name.
> > This according to article on
> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-co
> nfigure-postgis-raster-on-windows.
> > 4) But when I run makepostgisdb.bat again, I found another errors
> > "can't find libiconv-2.dll....please re-install"
> > Do anyone can help me with this?
> > Thank you.
> > Regards,
> > Wendi A
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Hello,
> Renaming the dll file was a solution suggested by a Windows
> XP SP2 user. Are you in the same situation? I didn't need to
> do that using Windows 7.
> About the execution of the bat file, could you please send us
> the output? Did you experiment any other problems following
> the previous steps?
> I've responded you in the blog post too. But we can keep the
> question in the list (it has a wider audience)
> Jorge Arévalo
> Internet & Mobility Division, DEIMOS
> jorge.arevalo at deimos-space.com
> http://es.linkedin.com/in/jorgearevalo80
> http://mobility.grupodeimos.com/
> http://geohash.org/ezjqgrgzz0g
