[postgis-users] Need Help :How to Install PostGIS Raster
Jorge Arévalo jorge.arevalo at deimos-space.com
Fri Oct 7 01:09:50 PDT 2011
Hi Wendi,
"mercator" is the name of one of my machines. In the PgAdmin GUI tree
you can see your defined connections. I have 3 connections defined.
When you define your own connections, you'll see them at same place.
Best regards,
Jorge
2011/10/7  <wendiadriansaga at yahoo.com>:
> Hi Jorge,
> Can you let me know how to make Mercator and PostGIS Raster appear on PgAdmin tree on GUI? Because they are not appear on my PgAdmin III.
> Please help me.
> Thanks.
> Regards,
> Wendi A
> Powered by Telkomsel BlackBerry®
> -----Original Message-----
> From: Jorge Arévalo <jorge.arevalo at deimos-space.com>
> Date: Thu, 6 Oct 2011 10:18:27
> To: Wendi Adrian<wendiadriansaga at yahoo.com>; PostGIS Users Discussion<postgis-users at postgis.refractions.net>
> Subject: Re: [postgis-users] Need Help :How to Install PostGIS Raster
> On Thu, Oct 6, 2011 at 2:55 AM, Wendi Adrian <wendiadriansaga at yahoo.com> wrote:
>> Dear all,
>> it is great for me to join with you in PostGIS user milist. :)
>> I need your advices, maybe some of you have found same problems with me.
>> I have installed PostgreSQL v.9.0 and want to install PostGIS v.2.0 which I
>> have download from Postgis website. The files was called postgis-2.0.0 SVN.
>> This supports PostGIS Raster database based on documentation I found.
>> I try to install it, but always find errors which can described as follow ;
>> 1) I use command prompt to run makepostgisdb.bat but I adapt environmental
>> variables in windows according to parameters.
>> 2) when I run it, I get notification "operation aborted...transaction block"
>> 3) I rename libiconv-2.dll in Postgresql/8.4/bin folder to any other name.
>> This according to article on
>> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-configure-postgis-raster-on-windows.
>> 4) But when I run makepostgisdb.bat again, I found another errors "can't
>> find libiconv-2.dll....please re-install"
>> Do anyone can help me with this?
>> Thank you.
>> Regards,
>> Wendi A
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Hello,
> Renaming the dll file was a solution suggested by a Windows XP SP2
> user. Are you in the same situation? I didn't need to do that using
> Windows 7.
> About the execution of the bat file, could you please send us the
> output? Did you experiment any other problems following the previous
> steps?
> I've responded you in the blog post too. But we can keep the question
> in the list (it has a wider audience)
> Jorge Arévalo
> Internet & Mobility Division, DEIMOS
> http://es.linkedin.com/in/jorgearevalo80
> http://mobility.grupodeimos.com/
> http://geohash.org/ezjqgrgzz0g
Jorge Arévalo
