[postgis-users] set nr of decimales without changing field type
Gery . gamejihou at hotmail.com
Fri Oct 7 12:29:41 PDT 2011
Thanks Puneet for the link, it worked like a charm.
@Sandro: also, I forgot to thank you, the link is very useful, although it'd be great if more examples could be added there.
Thanks guys, PostGis rocks.
> From: gamejihou at hotmail.com
> To: postgis-users at postgis.refractions.net
> Subject: set nr of decimales without changing field type
> Date: Fri, 7 Oct 2011 16:33:05 +0000
> Hi,
> I'm calculating some distances and getting too many decimals, I just want 4 decimals, this is the code:
> UPDATE line SET length_km = st_length(st_transform(geom,32718))/1000 WHERE id::int between 1 and 75;
> and the result is for example:
> 75.1634098489817
> Is it possible to set the number of decimals in the code above?
> Thanks,
