[postgis-users] Placing a random point within a range of distances from existing point, ST_DWithin and ST_Intersects
Stephen V. Mather svm at clevelandmetroparks.com
Fri Oct 28 05:59:26 PDT 2011
Ah, never mind this question.  I don't have the function exit if it can't
find a point to place, but have it raise a notice, place the point and move
on.  Of course I occasionally get points that don't qualify. .
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
V. Mather
Sent: Wednesday, October 26, 2011 10:28 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Placing a random point within a range of distances
Hi All,
                I'm trying to find the problem with my logic in the
following query.  I want to randomize a point, and neither place it too
close or too far from the initial point.  I'd like to further constrain the
placement of that point so that it stays within certain bounds.  Imagine, if
you will sensitive point data that might need a little fuzzing-1) I don't
want to fuzz it too much (outer circle), 2) I don't want it too close to the
original point (inner circle) 3) but I want it to also stay within certain
boundaries in order to retain some verisimilitude, e.g. must stay within
forest boundaries.
I've tested this in PostGIS 1.3.5 on a Windows Server 2003 machine (postgres
8.3), and in PostGIS 2.0 on Debian (with postgres 8.4).
In general, it works really well.  Occasionally, I get a point that seems to
meet my first to criteria but not my third
Here's a few hundred of the same point fuzzed:
Function:
CREATE OR REPLACE FUNCTION ST_Donut
                ( geom GEOMETRY,
-- GEOMETRY point to be processed
                dough DOUBLE PRECISION,
-- Outside ring
                nut DOUBLE PRECISION,
-- Inside ring
                itermax INTEGER,
-- Maximum number of iterations
                bite GEOMETRY)
--POLYGON that randomized point must intersect
                RETURNS GEOMETRY
-- Returns the randomized point
                AS $$
                DECLARE
                                xmin DOUBLE PRECISION;
-- xmin for envelope of donut
                                ymin DOUBLE PRECISION;
-- ymin for envelope of donut
                                delta DOUBLE PRECISION;
-- difference between xmax and xmin
                                pointx DOUBLE PRECISION;
-- output point x
                                pointy DOUBLE PRECISION;
-- output point y
                                returnpoint GEOMETRY;
                                i INTEGER := 0;
-- index integer for while loop
                BEGIN
                                xmin = ST_X( geom ) - dough;    -- find min
x, min y for resulting envelope
                                ymin = ST_Y( geom ) - dough;     -- in which
to place initial points
                                delta = dough*2;
-- for calculating max extent for envelope
                WHILE i < itermax LOOP
                                i = i + 1;
                                pointx = xmin + delta * random();
-- generate random point value
                                pointy = ymin + delta * random();
                                returnpoint = ST_SetSRID( ST_MakePoint(
pointx, pointy ), ST_SRID( geom ) );
                EXIT WHEN
                                ST_DWithin( returnpoint, geom, dough )
-- test to see if inside outer ring
                                                AND NOT
                                ST_DWithin( returnpoint, geom, nut )
-- test to see if outside inner ring
                                                AND
                                ST_Intersects( returnpoint, bite )
--test to see if inside inclusion polygon
                END LOOP;
                IF i > itermax THEN
                                RAISE NOTICE 'Reached maximum iterations
without placing point inside donut.';
                END IF;
                RETURN returnpoint;     -- return the GEOMETRY
                END;
$$ LANGUAGE plpgsql;
To run:
CREATE TABLE donut_bite_test1 AS
SELECT ST_Donut(ST_MakePoint(0, 0), 40, 60, 1000,
ST_Buffer(ST_MakePoint(-60, -60), 60))
UNION ALL
SELECT ST_Donut(ST_MakePoint(0, 0), 60, 40, 1000,
UNION ALL
Etc. etc.
Best,
Steve
(216) 635-3243
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111028/8fe18ea5/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111028/8fe18ea5/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111028/8fe18ea5/attachment-0001.png>
