[postgis-users] Question about st_difference
G. van Es gves2000 at yahoo.com
Wed Sep 7 23:48:14 PDT 2011
Hi Nicolas and Chris,
Thanks for pointing me in the right direction. On a small scale it works great. Now the job is to implement it on tables with 7million records.
Thanks again and kind regards,
Ge
From: Chris Hermansen <chris.hermansen at tecogroup.ca>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Wednesday, September 7, 2011 8:39 PM
Subject: Re: [postgis-users] Question about st_difference
In addition to Nicolas' suggestion, one thing that can work, for example when the goal is to "make holes" with one theme in another, is to st_union the two themes, then re-attribute, then delete the unwanted polygons.  This has worked for me in relatively small datasets but I've never truly stress tested it.
2011/9/7 Nicolas Ribot <nicolas.ribot at gmail.com>
> Hello Group,
>> About st_difference I've seen several topics but unfortunately with none of them I could solve my problem.
>> What I want to do is subtract one layer from the other. I could simplify this down to the following;
>> Tbl_a contains 1 record
>> "POLYGON(((168119.443682473 451093.811197312,197555.469699649 451093.811197312,197555.469699649 437539.54805452,168119.443682473 437539.54805452,168119.443682473 437539.54805452,168119.443682473 451093.811197312)))"
>> Tbl_b contains 2 records of which both intersects with the object in tbl_a
>> "POLYGON(((171424.484910418 453680.34544058,171424.484910418 435697.56759188,174568.140889894 435697.56759188,174568.140889894 453680.34544058,174568.140889894 453680.34544058,171424.484910418 453680.34544058)))"
>> "POLYGON(((184904.90800885 453627.063135843,184904.90800885 435644.285287143,188048.563988327 435644.285287143,188048.563988327 453627.063135843,188048.563988327 453627.063135843,184904.90800885 453627.063135843)))"
>> The result I'm looking for is the object of tbl_a abstracted with both objects from tbl_b, since they are both intersecting. In this example the result should be 3 squares since it is cut twice by tbl_b.
>> Does anyone know a solution for this?
>> Many thanks in advance,
>> Ge
>Hi Ge,
>You may want to union objects in table B to create a single polygon,
>then perfom the difference:
>select st_difference(a.geom, b.geom)
>from
>(select 'POLYGON((168119.443682473 451093.811197312,197555.469699649
>451093.811197312))'::geometry as geom) as a,
>select st_union(geom) as geom
>from (
>       select 'POLYGON((171424.484910418 453680.34544058,171424.484910418
>453680.34544058))'::geometry as geom
>       UNION
>       select 'POLYGON((184904.90800885 453627.063135843,184904.90800885
>453627.063135843))'::geometry as geom
>) as foo
>) as b;
>(see attached pictures)
>Nicolas
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Chris Hermansen
Vice President
TECO Natural Resource Group Limited
301 · 958 West 8th Avenue
Vancouver BC CANADA · V5Z 1E5
Tel +1.604.714.2878 · Cel +1.778.840.4625
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110907/0286d4e7/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110907/0286d4e7/attachment.jpg>
