[postgis-users] Postgis topology help
pcreso at pcreso.com pcreso at pcreso.com
Wed Apr 4 09:57:10 PDT 2012
Following on from the reply by strk (thanks!!) I'm still working through how to use topologies.
I have a script which creates a topology, adds 5 linestrings looking like:
validates the result and then Polygonizes it, creating two faces.
I'm using the SVN docs
( http://www.postgis.org/documentation/manual-svn/Topology.html )
as my reference, as this is the best I have found so far.
What I want this script to do is run a query listing/describing the faces that have been created, then extract them as polygon geometries into a Postgis geometry column to be used as conventional polygons, but I can see no way in the docs of accomplishing this.
Once I get the script able to complete this operation I figure I should have a much better understanding of how Postgis topology works, & will stick it on the wiki as a working example. I'll also insert more commands to illustrate other operations, as I learn this stuff.
Any suggestions as to how to accomplish these next steps?
Thanks,
  Brent Wood
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120404/de81e8fb/attachment.html>
