[postgis-users] ST_MakeValid
Stephen V. Mather svm at clevelandmetroparks.com
Mon Apr 16 09:33:15 PDT 2012
Hi All,
                Has anyone done any performance tests on ST_MakeValid?  I
had been using Tim Sutton's cleanGeometry function from circa 2010
(http://linfiniti.com/2010/07/cleaning-geometries-inside-postgis/) to clean
up geometries.  Works most of the time-every now and then I throw it
something too big and harry and it runs for weeks and weeks and never (AFAI
have the patience for) completes.  I've been looking forward to
ST_MakeValid.
                Today, a new Postgis 2.0 instance in hand, I was playing
with a dataset with 9106 invalid geometries-all self intersecting geometries
from raster-->vector conversion in an un-named proprietary package.  On a
whim, I decided to compare the speed of ST_MakeValid to Tim's code, so first
I needed the correct functions:
psql -U postgres -d test -f "C:\Program
Files\PostgreSQL\9.1\share\contrib\postgis-2.0\legacy.sql"
Then a quick run through cleanGeometry:
CREATE TABLE tpi_clean AS
     SELECT gid, id, gridcode, "class name", cleanGeometry(geom)
           FROM tpi;
And I get back:
Query returned successfully: 1004952 rows affected, 955444 ms execution
time.
If I run as ST_MakeValid,
CREATE TABLE tpi_valid AS
     SELECT gid, id, gridcode, "class name", ST_MakeValid(geom)
           FROM tpi;
At 2300000 milliseconds, it is still running. .
This is PostgreSQL 9.1, PostGIS 2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1, on
Windows XP 32-bit.  I have not yet tested on my Ubuntu box. .
Thanks,
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120416/bb2da6ae/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120416/bb2da6ae/attachment.png>
