[postgis-users] Geom/Rast Intersection St9bad_alloc
JamesH james.holmes at newcastle.ac.uk
Tue Apr 24 05:04:50 PDT 2012
I am attempting to intersect a vector dataset of building polygons with a
3-Band Thermal tiff to produce a dataset that shows the thermal readings for
each polygon.
"What were you trying to achieve ? Did you read the reference manual ?"
I hoped from the example in the reference
"-- Return bands 2 and 3. Use array to define bands
SELECT ST_NumBands(ST_Band(rast, ARRAY[2,3])) "
that I could use ST_Band(rast, ARRAY[1,2,3]) to perform the intersection on
all three bands simultaneously.
Is there an easier way of completing this?
Regards,
James
GIS Undergraduate
View this message in context: http://postgis.17.n6.nabble.com/Geom-Rast-Intersection-St9bad-alloc-tp4912994p4913238.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
