[postgis-users] banging my head on setting up and running geodjango
Smaran Harihar smaran.harihar at gmail.com
Tue Apr 24 10:03:16 PDT 2012
I am really fed up in setting up and running GeoDjango.
The first step was to setup the Spatial Database in PostGIS which I was
really banging my head when it came to OS X. So i shifted to Ubuntu 11.10
and it seemed it was quite easy. Now having completed the post installation
process<https://docs.djangoproject.com/en/dev/ref/contrib/gis/install/#creating-a-spatial-database-template-for-postgis>,
I created the required changes that need to be done in the settings.py and
now i am trying to,
python manage.py sqlall world
but it is returning a bunch of errors.
(django-env)smaranh at ubuntu:~/geodjango$ python manage.py sqlall world
  File "manage.py", line 10, in <module>
    execute_from_command_line(sys.argv)
  File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 443, in execute_from_command_line
    utility.execute()
  File
line 382, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
line 261, in fetch_command
    klass = load_command_class(app_name, subcommand)
  File
line 69, in load_command_class
    module = import_module('%s.management.commands.%s' % (app_name, name))
  File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/utils/importlib.py",
line 35, in import_module
    __import__(name)
  File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/core/management/commands/sqlall.py",
line 4, in <module>
    from django.core.management.sql import sql_all
  File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/core/management/sql.py",
line 6, in <module>
    from django.db import models
  File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/db/__init__.py",
line 40, in <module>
    backend = load_backend(connection.settings_dict['ENGINE'])
  File
line 34, in __getattr__
    return getattr(connections[DEFAULT_DB_ALIAS], item)
  File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/db/utils.py",
line 92, in __getitem__
    backend = load_backend(db['ENGINE'])
  File
line 44, in load_backend
    raise ImproperlyConfigured(error_msg)
django.core.exceptions.ImproperlyConfigured:
'django.contrib.gis.db.backends.postgis' isn't an available database
backend.
Try using django.db.backends.XXX, where XXX is one of:
    'dummy', 'mysql', 'oracle', 'postgresql_psycopg2', 'sqlite3'
Error was: No module named psycopg2.extensions
Really need your help guys.
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120424/1432c4f8/attachment.html>
