[postgis-users] Could not add all rasters to a table
Olivier Courtin olivier.courtin at oslandia.com
Wed Aug 15 07:47:59 PDT 2012
Hi Park,
I could not find gdalinfo.exe on my windows machine. I have installed postgis 2.0. Should I install gdalinfo separately? I could not google to the application download. Where should I find it?
I could not find scale x/y values for the raster files. Moreover, I do not see any problem in viewing them in ArcMap. They might overlap little bit on the edges. But that is usually the case with raster images.
Any help to sort of the problem. Thanks.
Date: Tue, 14 Aug 2012 11:43:51 -0700
Subject: Re: [postgis-users] Could not add all rasters to a table.
To: postgis-users at postgis.refractions.net
Message-ID: <502A9C67.5040901 at ucdavis.edu>
Content-Type: text/plain; charset=ISO-8859-1
The error is just that: at least one raster isn't aligned with the other rasters being added to that table.  One way to see what could be going on is to use gdalinfo on the four rasters.  Check the values for the upper-left corner, scale and skew.  The scale and skew should be the same while the upper-left corners should be divisible without a remainder...
(rast1X - rast2X) / scaleX = whole number
(rast1Y - rast2Y) / scaleY = whole number
If all that looks good, post the outputs from gdalinfo for all four rasters so that I can take a look and see if there are strange floating point issues...
-bborie
On 08/14/2012 11:32 AM, Melpati, Muni wrote:
> Hi,
> I am getting this error "raster with different alignment found in the set of rasters being converted to postgis raster" while I load all four jpg files into a new table. When I view them ArcMap they just seems to align well.
> What must be going wrong?
> Here is the text in the bat file:
> path=%path%;"E:\PostgreSQL\8.4\bin
> cd /D "%~dp0"
> raster2pgsql -I -C -e -Y -F -s 26986 -t 300x300  -l 2,4
> F:\PostGIS\raster\*.jpg private_schema.rasterly1 | psql -h localhost
> -U postgres -d gis_raster -p 5433
> pause
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120815/1988e576/attachment.html>
