[postgis-users] difference in query performance due to the inclusion of a polygon geometry field - SOLVED
ivan marchesini ivan.marchesini at gmail.com
Wed Dec 5 07:58:55 PST 2012
thanks Sandro...
bingo Nicklas,
it was a problem of geometry tranfer from the server to the client.
Your test with st_areas allows me to discover that the vector layer was
too much detailed.
I generalized it and now the query time is gone down to 1 second..
many many thanks
ivan
Il giorno lun, 03/12/2012 alle 11.50 +0100, Nicklas Av?n ha scritto:
> Hallo
> To sort out if the bottleneck is internal in the db or just the transfer
> of the geometries from the database to your client you can try to run some
> function that is not too costly but have to alter the whole geometry,
> just returning a number, for instance ST_Area
> So, if you run your query, but instead of including the geometry do
> "ST_Area(geometry)"
> What timing do you get then?
> /Nicklas
> 2012-12-03 ivan marchesini wrote:
> Dear users,
> >I apologize for cross-posting since I already sent this request to
> the
> >PostgreSQL Mailing List. But given the answers probably this is the
> >right mailing list for our problem.
> > We are facing with a strange efficiency problem.
> >We have two tables:
> >1) the first largest (30000 rows) contains a timestamp field (named
> >"tempo_calcolo") and other fields.
> >2) the second contains only few rows (150), a PostGIS geometric
> POLYGON
> >field (named "the_geom") and other fields.
> >The query we want to execute is a join between the two table based on
> a
> >common field, filtered by the timestamp field and ordered by the same
> >field.
> >Including and excluding the PostGIS geometric POLYGON field (that is
> not
> >used neither in the joining or in the filtering) the execution times
> are
> >really different.
> >Without the geometric field it takes around 86 ms !!
> >With the geometric field it takes around 14000 ms !!
> >These are the EXPLAIN ANALYSE results obtained when we perform the
> query
> >without the geometric field:
> >____________________________
> >"Sort (cost=1217.29..1240.40 rows=9246 width=133) (actual
> >time=2.964..3.095 rows=1474 loops=1)"
> >" Sort Key: storico_zone_allertamento.tempo_calcolo"
> >" Sort Method: quicksort Memory: 440kB"
> >" InitPlan 1 (returns $0)"
> >" -> Result (cost=0.00..0.02 rows=1 width=0) (actual
> >time=0.022..0.022 rows=1 loops=1)"
> >" -> Hash Join (cost=6.01..608.21 rows=9246 width=133) (actual
> >time=0.143..1.916 rows=1474 loops=1)"
> >" Hash Cond: (storico_zone_allertamento.gid_fk =
> >zone_allertamento.gid)"
> >" -> Index Scan using
> >index_storico_zone_allertamento_tempo_calcolo on
> >storico_zone_allertamento (cost=0.00..475.06 rows=9246 width=112)
> >(actual time=0.042..0.440 rows=1474 loops=1)"
> >" Index Cond: (tempo_calcolo > $0)"
> >" -> Hash (cost=4.34..4.34 rows=134 width=25) (actual
> >time=0.090..0.090 rows=134 loops=1)"
> >" Buckets: 1024 Batches: 1 Memory Usage: 8kB"
> >" -> Seq Scan on zone_allertamento (cost=0.00..4.34
> >rows=134 width=25) (actual time=0.004..0.035 rows=134 loops=1)"
> >"Total runtime: 3.285 ms"
> query
> >with the geometric field:
> >"Sort (cost=776019.29..776042.40 rows=9246 width=196111) (actual
> >time=3.039..3.163 rows=1474 loops=1)"
> >" Sort Method: quicksort Memory: 567kB"
> >time=0.009..0.009 rows=1 loops=1)"
> >" -> Hash Join (cost=6.01..608.21 rows=9246 width=196111) (actual
> >time=0.139..1.957 rows=1474 loops=1)"
> >(actual time=0.029..0.431 rows=1474 loops=1)"
> >" -> Hash (cost=4.34..4.34 rows=134 width=196003) (actual
> >time=0.091..0.091 rows=134 loops=1)"
> >" Buckets: 1024 Batches: 1 Memory Usage: 19kB"
> >rows=134 width=196003) (actual time=0.006..0.038 rows=134 loops=1)"
> >"Total runtime: 3.355 ms"
> >It seems that the difference is primary in the "width" and then in
> the
> >"cost" of the Sort.
> >A similar task performed on two similar tables (both larger than the
> >previous ones!!) but including and excluding a PostGIS geometric
> POINT
> >(!!) field instead of POLYGON one, doesn't result in significant
> query
> >execution time difference.
> >Do you have please any suggestion to improve our query efficiency??
> >In the PostgreSQL mailing Tom Lane suggest that the problem could be
> due
> >to:
> > (1) time to fetch the wide geometry values from the table's
> > TOAST table
> > (2) time to convert the geometry values to text form
> > (3) time to transmit the larger volume of data to the client
> > (4) client-side processing time
> > None of these costs are expended in an EXPLAIN ANALYZE, which is
> > why the time reported for that doesn't change materially.
> >We think that the first is the most probable cause of the high query
> >execution time, because the query is a simple join( without, we
> think,
> >conversion from geometry to text), the delay is confirmed also using
> >psql on the server, the client side processing time should be really
> >small since data are really few.
> >Can you suggest a way to solve this problem?
> >Any suggestion is really appreciated !!!!
> >Thanks in advance
> >Ivan and Mauro
> >Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
> >Preferisco formati liberi.
> >Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
> >I prefer free formats.
> >http://it.wikipedia.org/wiki/Formato_aperto
> >http://en.wikipedia.org/wiki/Open_format
> >Ivan Marchesini
> >Perugia (Italy)
> >Socio fondatore GFOSS "Geospatial Free and Open Source Software"
> http://www.gfoss.it
> >e-mail: ivan.marchesini at irpi.cnr.it
> >fax (mailfax): +39 1782092534
> >jabber: geoivan73 at jabber.org
> >skype: geoivan73
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at lists.osgeo.org
> >http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Ivan Marchesini
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
skype: geoivan73
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121205/69bc5a5c/attachment.pgp>
