[postgis-users] plpgsql function question, equivalent sql statement?
Nathaniel Hunter Clay clay.nathaniel at gmail.com
Sun Dec 9 07:19:20 PST 2012
Hi all,
I am wondering if there is a better way do accomplish the following.  To
create an array of values between two points from a raster. This is what
I have come up with.
  CREATE or REPLACE Function sampledArray(rast raster, bandnum integer,
p1 geometry,p2 geometry, sampledistance double precision) RETURNS double
precision[] AS
DECLARE
     line geometry;
     distance double precision;
     samples integer;
     sample double precision;
     valuesarray double precision[];
BEGIN
     line := ST_MakeLine($3,$4);
     distance := ST_Distance($3,$4);
     samples := floor(distance/sampledistance);
     sample  := sampledistance/distance;
     for i in 0..samples by 1
         LOOP
         valuesarray[i] :=
ST_Value($1,$2,ST_Line_Interpolate_Point(line,sample*i));
         END LOOP;
     return valuesarray;
END;
LANGUAGE plpgsql;
