[postgis-users] shp2pgsql error
Sandro Santilli strk at keybit.net
Fri Dec 14 07:47:59 PST 2012
On Fri, Dec 14, 2012 at 10:41:30AM -0500, Jeff Lake wrote:
> I am root ...
sudo won't hurt
> besides, isn't needed when installing 2.0.1
I see you're query linking of binary in /usr but you have libraries in
/usr/local. So mixed packaged and manually built stuff.
Tried ldd /usr/local/bin/shp2pgsql after install of 2.0.2 ?
--strk;
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 12/14/2012 10:30, Sandro Santilli wrote:
> >Sounds like you didn't run "sudo ldconfig" after install of 2.0.2.
> >Possible ?
> >--strk;
> >On Fri, Dec 14, 2012 at 10:06:37AM -0500, Jeff Lake wrote:
> >>just a follow up, I had to revert back to postGIS2.0.1 as this is a
> >>full production database server...
> >>interesting enough, this is the output from ldd /usr/bin/shp2pgsql
> >>quite the difference, both versions built with the same configure flag
> >>         linux-vdso.so.1 =>  (0x00007fff4b3f8000)
> >>         liblwgeom-2.0.1.so => /usr/local/lib/liblwgeom-2.0.1.so
> >>(0x00007fe6b2e9a000)
> >>         libgeos_c.so.1 => /usr/lib64/libgeos_c.so.1 (0x00007fe6b2c75000)
> >>         libproj.so.0 => /usr/lib64/libproj.so.0 (0x0000003633e00000)
> >>         libc.so.6 => /lib64/libc.so.6 (0x0000003633a00000)
> >>         libgeos-3.3.6.so => /usr/lib64/libgeos-3.3.6.so
> >>(0x00007fe6b28e2000)
> >>         libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003032200000)
> >>         libm.so.6 => /lib64/libm.so.6 (0x0000003634600000)
> >>         libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003031600000)
> >>         /lib64/ld-linux-x86-64.so.2 (0x0000003633600000)
> >>*Jeff Lake*
> >>On 12/14/2012 9:20, Jeff Lake wrote:
> >>>I just upgraded my postGIS2.0.1 to 2.0.2 from source..
> >>>Now, I'm getting this error
> >>>shp2pgsql: error while loading shared libraries:
> >>>liblwgeom-2.0.2.so: cannot open shared object file: No such file
> >>>or directory
> >>>liblwgeom-2.0.2.so  was found in /usr/local/lib/
> >>>#    ldd /usr/bin/shp2pgsql
> >>>        linux-vdso.so.1 =>  (0x00007fff27c5a000)
> >>>        liblwgeom-2.0.2.so => not found
> >>>I must have missed a configure flag, but which one ??
> >>>*Jeff Lake*
> >>>_______________________________________________
> >>>postgis-users mailing list
> >>>postgis-users at lists.osgeo.org
> >>>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
