[postgis-users] PostGIS - Simple Raster Point Query
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Dec 18 13:56:30 PST 2012
Try this (adapting the linestring to match your raster extent):
SELECT p, geom, ST_Value(rast,geom) elev
FROM (SELECT p, ST_line_interpolate_point(
                  ST_GeometryFromText('LINESTRING(-69 46.5, -68 46, -67 46.5, -67 45)', 4326),
                                      CAST(p AS numeric)/30) geom
            FROM generate_series(1,30) p
           ) foo,
         srtm_tiled_100x100
WHERE ST_Intersects(rast, geom)
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Tim-Hinnerk Heuer
> Sent: Tuesday, December 18, 2012 3:09 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS - Simple Raster Point Query
> Hi Pierre,
> Sorry, I might not have been 100% clear. What you say is exactly what I want to
> achieve. That's the reason I'm posting the question here, because I do not want
> to run 40 odd queries if I can do it with one. Since I'm new to PostGIS though, I
> don't know how to, hence why I'm asking.
> Thanks,
> Tim
> Tim-Hinnerk Heuer
> Twitter: @geekdenz
> Blog: http://www.thheuer.com <http://www.thheuer.com/>
> On 18 December 2012 08:53, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> 	When you say: "one query is run for each point on the line", you mean
> your application does.
> 	Why don't you just create a complex query that will do everything in SQL
> so PostgreSQL will take charge of everything and optimize the management of
> the row reading for this single query? This is the advantage of having a complete
> GIS SQL API in the database.
> 	Pierre
> 	> Sent: Friday, December 14, 2012 7:32 PM
> 	> Good point and apologies I haven't been more clear.
> 	> We want to achieve this:
> http://npm.landcareresearch.co.nz/elevation/
> 	> with Open Source technology and our own data. Also, instead of doing
> a single
> 	> line, we want to implement a LineString which can have multiple
> control points
> 	> in it.
> 	> So far we've got it working by querying for each point on the line, say
> n
> 	> segments would give us n+1 points on the line and therefore n+1
> queries which
> 	> could potentially be a lot. At the moment one query is run for each
> point on the
> 	> line, which is fine, but I believe there must be a much better way with
> PostGIS to
> 	> get all the points' st_values at once, preferably, like in the example
> above, also
> 	> the distance of each point from the first point on the line.
> 	> Thought an example application, similar to the one we are developing
> would be
> 	> better than a thousand words.
> 	> Thanks for all your help.
> 	> Regards,
> 	> Tim
> 	> Tim-Hinnerk Heuer
> 	> Twitter: @geekdenz
> 	> On 15 December 2012 13:18, Pierre Racine
> 	> wrote:
> 	>       Maybe it would be better to describe more generally what you are
> 	> trying to achieve. Most complex processing can normally be achieved
> in one
> 	> complex query.
> 	>       PostgreSQL should cache what was loaded in previous queries so
> that it
> 	> does not necessarily reload tiles at each query.
> 	>       Pierre
> 	>       > We query the points on the line with one query for each point.
> This
> 	> could be
> 	>       > optimised like this:
> 	>       > SELECT ST_AsText(
> 	>       > ST_GeometryFromText('LINESTRING(0 0,0 1,1 1)'), CAST(p AS
> 	> numeric)/10
> 	>       > FROM generate_series(1,10) p;
> 	>       > to get all points. But this is still requiring one query for each point
> on
> 	> the line. I
> 	>       > suspect, if we were to query all points at once, there will have to
> be
> 	> less reading
> 	>       > of the raster, because the points are likely to be on the same tile.
> 	> However, I do
> 	>       > not know how to achieve that. Can I somehow intersect the line
> with
> 	> the raster
> 	>       > and query all the points above?
> 	>       > Any hints would be greatly appreciated.
> 	>       > Thanks,
> 	>       > Tim
> 	>       > Tim-Hinnerk Heuer
> 	>       > Twitter: @geekdenz
> 	>       > On 9 December 2012 20:36, Tim-Hinnerk Heuer
> 	> <th.heuer at gmail.com> wrote:
> 	>       >       Hi Pierre,
> 	>       >       Great! Thank you so much, that worked!
> 	>       >       You're a genius!
> 	>       >       In case you are wondering. That point is Mount Ruhapehu and
> it
> 	> gave
> 	>       > me the answer: 2611.7314453125 (m) which is indeed correct.
> 	>       >       Kind regards,
> 	>       >       Tim
> 	>       >       Tim-Hinnerk Heuer
> 	>       >       Twitter: @geekdenz
> 	>       >       On 9 December 2012 20:24, Pierre Racine
> 	>       > <Pierre.Racine at sbf.ulaval.ca> wrote:
> 	>       >               SELECT ST_Value(rast,ST_SetSRID(ST_Point(1821416,
> 	> 5649720),
> 	>       > 2193))
> 	>       >               FROM nzdem3
> 	>       >               WHERE
> ST_Intersects(rast,ST_SetSRID(ST_Point(1821416,
> 	>       > 5649720), 2193))
> 	>       _______________________________________________
> 	>       postgis-users mailing list
> 	>       postgis-users at lists.osgeo.org
> 	>       http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
