[postgis-users] PostGIS 2.0 instalation problem
wobo mcwobo at hotmail.com
Tue Dec 18 16:55:43 PST 2012
Regina,
I guess this e-mail was intended for somebody else (Willy).I still haven't been able to install PostGIS 2.0 on my Windows XP, but am using it on Windows 7 succesfully.
Yours sincerely,Wouter
Date: Tue, 18 Dec 2012 15:48:57 -0800
To: mcwobo at hotmail.com
Subject: Re: PostGIS 2.0 instalation problem
Willy,
when you say compressed postgis file -- you mean the one on
this page?
http://www.postgis.org/download/windows/#windbinaries
I unfortunately don't have a windows xp machine readily handy
to test with.  I haven't tried upgrading my test to 9.1.7 to rule that out
as an issue so I'll give that a try.
This issue is usually caused by libxml2-2.dll
incompatibilities.  Though I gather you are using the one packaged with
PostGIS since it looks like the postgres one isu using
libxml2.dll
Have you been running PostGIS 2 or 1.5 on your windows xp
successfully in past
Thanks,
Regina
http://www.postgis.us
Sent: Tuesday, December 18, 2012 11:30 AM
To: PostGIS Users
Discussion; Paragon Corporation
Subject: Re: [postgis-users] PostGIS
I have the same problem.
I installed postgres on an XP PC, which worked fine. (PostgreSQL 9.1.7,
compiled by Visual C++ build 1500, 32-bit)
Then I used the StackBuilder to install PostGIS 2.
Upon creating the extension, i get the error "ERROR: could not load library
"C:/Program Files/PostgreSQL/9.1/lib/postgis-2.0.dll": unknown error
998"
The same happens when executing the sql "create extension
postgis;"
I tried pasting the contents from the bin folder from the
compressed postgis installation file into ../9.1/bin/, but to no
avail.
I used Depends.exe to diagnose, like Paragon suggested.
I
included the dwi-file as an attachment.
Is there anything i can
do?
Cheers,
WBL
On Sat, May 19, 2012 at 2:50 AM, wobo <[hidden email]> wrote:
So, I've been trying to install PostGIS 2.0 over and over
  again on several
different Windows XP computers, but didn't succeed in
  getting it up and
running. So I ended up borrowing my brother's Windows 7
  pc, using the exact
same download (postgreSQL + postgis using stackbuilder)
  which took me about
5 minutes to succesfully install the whole
  thing.
I have no clue why it doesn't work on my XP. More exactly, why
  it can't find
the correctly located postgis-2.0.dll-file. But at least I'll
  be able to
test and recap the 'PostGIS in Action' on Windows 7 from now
  on.
Many thanks for suggesting and helping anyway.
View
  this message in context: http://postgis.17.n6.nabble.com/PostGIS-2-0-instalation-problem-tp4624902p4993596.html
  Sent from the PostGIS - User mailing list archive at
  Nabble.com.
postgis-users
[hidden email]
http://postgis.refractions.net/mailman/listinfo/postgis-users
"Quality comes from focus and clarity of purpose" -- Mark
Shuttleworth
postgis-users mailing list
[hidden email]
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
		If you reply to this email, your message will be added to the discussion below:
		http://postgis.17.n6.nabble.com/PostGIS-2-0-instalation-problem-tp4624902p5002094.html
		To unsubscribe from PostGIS 2.0 instalation problem, click here.
		NAML
View this message in context: http://postgis.17.n6.nabble.com/PostGIS-2-0-instalation-problem-tp4624902p5002096.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121218/d5b814a1/attachment.html>
