[postgis-users] Using PostGIS for latitude & longitude
nevillekb nevillekb at gmail.com
Mon Dec 24 04:32:47 PST 2012
So i created a table named zipcode with the following columns
Id
State
Zip
Latitude
Longitude
column1
column2
columns named column1 and column2 are the 2 geometry columns i have created
to store the lat and long in 2 formats -SRID 4269 (Lat/Lon) and SRID 2163
(US National Atlas – meters).
Then i execute the following query to populate both the columns with the lat
and lon data
UPDATE zipcode SET column1 =
ST_SetSRID(ST_MakePoint("longitude","latitude"),4269), column2 =
ST_Transform(ST_SetSRID(ST_MakePoint("longitude","latitude"),4269), 2163);
Everything has worked fine till now, but now when i try to execute the
following query to show all records that are within 5 miles of a given point
i get an error.
Query:
select state from zipcode where DISTANCE(column2,
ST_SetSRID('POINT(33.911404 -116.768347)', 2163)) < 8000;
Error Generated:
WARNING  ] select state from zipcode where DISTANCE(column2,
            ERROR:  function st_setsrid(unknown, integer) is not unique
            LINE 1: select state from zipcode where DISTANCE(column2,
ST_SetSRID...
            HINT:  Could not choose a best candidate function. You might
need to add explicit type casts.
Can someone help me out as to where am i going wrong in the above query??
Thanks
View this message in context: http://postgis.17.n6.nabble.com/Using-PostGIS-for-latitude-longitude-tp5002097p5002125.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
