[postgis-users] ST_Intersects(geom, geom) Memory issue
Andreas Forø Tollefsen andreasft at gmail.com
Fri Feb 3 01:03:57 PST 2012
Hi again,
I have a issue with the server crashing when running a simple query i have
been using together with previous versions of postgis on the same system.
The query intersects two tables with geometry. While i never have had
problems with this query before, it is now terminates my postgresql server.
It used to take ~5 min to complete, but now it terminates after 2 minutes.
When running the query i can see using top that memory rises to 96 % before
terminating the postgreql service.
My setup is Intel(R) Xeon(R) CPU E31270 @ 3.40GHz with 12GB of ram running:
                                                    version
 PostgreSQL 9.1.1 on x86_64-pc-linux-gnu, compiled by gcc-4.6.real
(Ubuntu/Linaro 4.6.1-9ubuntu3) 4.6.1, 64-bit
(1 row)
postgis_full_version
 POSTGIS="2.0.0alpha4SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
USE_STATS
(1 row)
shared_buffers = 4GB                    # min 128kB
temp_buffers = 64MB                     # min 800kB
work_mem = 64MB                 # min 64kB
maintenance_work_mem = 512MB            # min 1MB
Running the query:
DROP TABLE IF EXISTS geoepr_cell;
SELECT a.gid, g.startyear, g.endyear, g.cowgroup, a.gridyear INTO
geoepr_cell
FROM priogridall a, priogrid p, geoepreth2 g WHERE a.gid = p.gid AND
a.gridyear = 1946 AND a.gwcode = g.cowcode AND ST_Intersects(p.cell, g.geom)
AND g.startyear <= 1946 AND g.endyear >= 1946 GROUP BY a.gid, g.startyear,
g.endyear, g.cowgroup, a.gridyear ORDER BY gid ;
terminates the server with the below messages. I have used the
query previously without problems, but after updating to latest subversion
it do not work anymore. I am suspecting there is some memory issue.
I tried reducing the shared_buffers and disabling memory overcommit
(bottom: http://www.postgresql.org/docs/9.1/static/kernel-resources.html).
Any help on this would be very much welcome.
All the best,
Andreas
2012-02-03 09:27:01 CET DETAIL:  The postmaster has commanded this server
process to roll back the current transaction and exit, because another
server process exited abnormally and possibly corrupted shared memory.
2012-02-03 09:27:01 CET HINT:  In a moment you should be able to reconnect
to the database and repeat your command.
2012-02-03 09:27:02 CET LOG:  all server processes terminated;
reinitializing
2012-02-03 09:27:03 CET LOG:  database system was interrupted; last known
up at 2012-02-03 09:25:37 CET
2012-02-03 09:27:04 CET LOG:  database system was not properly shut down;
automatic recovery in progress
2012-02-03 09:27:04 CET LOG:  consistent recovery state reached at
7F/E90EF588
2012-02-03 09:27:04 CET LOG:  record with zero length at 7F/E90EF588
2012-02-03 09:27:04 CET LOG:  redo is not required
2012-02-03 09:27:04 CET LOG:  database system is ready to accept connections
2012-02-03 09:27:04 CET LOG:  autovacuum launcher started
2012-02-03 09:30:07 CET LOG:  incomplete startup packet
2012-02-03 09:30:08 CET LOG:  received fast shutdown request
2012-02-03 09:30:08 CET LOG:  aborting any active transactions
2012-02-03 09:30:09 CET LOG:  autovacuum launcher shutting down
2012-02-03 09:30:09 CET FATAL:  terminating connection due to administrator
command
command
2012-02-03 09:30:09 CET STATEMENT:  DROP TABLE IF EXISTS geoepr_cell;
geoepr_cell
AND a.gridyear = 1946 AND a.gwcode = g.cowcode AND ST_Intersects(p.cell,
g.geom)
g.startyear, g.endyear, g.cowgroup, a.gridyear ORDER BY gid ;
2012-02-03 09:31:09 CET LOG:  received immediate shutdown request
2012-02-03 09:31:09 CET WARNING:  terminating connection because of crash
of another server process
2012-02-03 09:31:09 CET DETAIL:  The postmaster has commanded this server
2012-02-03 09:31:09 CET HINT:  In a moment you should be able to reconnect
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120203/97bdc54f/attachment.html>
