[postgis-users] ST_Intersects(geom, geom) Memory issue
Paul Ramsey pramsey at opengeo.org
Wed Feb 8 08:48:37 PST 2012
Thanks for doing the legwork to find the offending commit! I've
re-opened #547 where the change originated.
On Wed, Feb 8, 2012 at 7:55 AM, Andreas Forø Tollefsen
<andreasft at gmail.com> wrote:
> I tested the query again and identified which commit of revisions
> introduced the problem.
> Until revision 8876 the query works fine.
> After revision 8877 the query leaks memory and eats up all of the
> servers memory in a couple of minutes.
> Tested:
> 8096 OK
> 8796 OK
> 8866 OK
> 8876 OK
> 8877 NOT OK
> 8886 NOT OK
> 8896 NOT OK
> 8996 NOT OK
> 9096 NOT OK
> Again the query was simply:
> SELECT a.gid, g.startyear, g.endyear, g.cowgroup, a.gridyear INTO geoepr_cell
> FROM priogridall a, priogrid p, geoepreth2 g WHERE a.gid = p.gid AND
> a.gridyear = 1946 AND a.gwcode = g.cowcode AND ST_Intersects(p.cell,
> g.geom)
> AND g.startyear <= 1946 AND g.endyear >= 1946 GROUP BY a.gid,
> g.startyear, g.endyear, g.cowgroup, a.gridyear ORDER BY gid ;
> Would be great if you could look into this.
> Best,
> Andreas
> 2012/2/4 Andreas Forø Tollefsen <andreasft at gmail.com>:
>> I created a new clean db and installed latest rev. Then loaded my tables and
>> ran the query with the same error and postgres server crash.
>> Any suggestions on how i can solve this? As for now i am using rev 8292 and
>> then the query and my raster summaries work.
