[postgis-users] Question about using ST_Transform()
David Quinn daithiquinn at gmail.com
Thu Feb 9 11:44:44 PST 2012
Thanks for the suggestion, Pierre.
I turned out to be a mistake on my part as I used the first Albers Equal
Area Conic listing I found on http://spatialreference.org. It turns out
there are two.....
ESRI:102003 <http://spatialreference.org/ref/esri/102003/>: USA Contiguous
Albers Equal Area Conic
ESRI:102008 <http://spatialreference.org/ref/esri/102008/>: North America
-David
On Thu, Feb 9, 2012 at 12:16 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> I generally display things in OpenJump to make sure they align correctly
> before doing anything instead of assuming they do. Do the projected
> geometries align properly with the rasters?
> You can display the raster extents easily in OpenJump by casting the
> raster to geometry (rast::geometry)...
> You can also do this easily in QGIS or ArcGIS 10.
> Pierre
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of David Quinn
> > Sent: Thursday, February 09, 2012 10:45 AM
> > To: PostGIS Users Discussion
> > Subject: [postgis-users] Question about using ST_Transform()
> > Hello All,
> > I'm trying to understand how to use ST_Transform() on a query. When I
> have
> > everything in the same projection (in this case Albers Equal Area Conic)
> my query
> > returns the correct result:
> > SELECT
> >     SUM((stats).sum)
> > FROM (
> >     select
> >         ST_SummaryStats(ST_Clip(r.rast, 1, p.geom, NULL, TRUE)) as stats
> >     FROM
> >         ny_albers as r,
> >         cities_albers as p
> >     WHERE
> >         p.name = 'new_york'
> >     AND
> >         ST_Intersects(r.rast, p.geom)
> >     )  as foo;
> > If I use a table with polygons in a different projection (in this case
> Web
> > Mercator), I do not get any values returned:
> > SELECT
> >     SUM((stats).sum)
> > FROM (
> >     select
> >         ST_SummaryStats(ST_Clip(r.rast, 1, ST_Transform(p.geom,102003),
> NULL,
> > TRUE)) as stats
> >     FROM
> >         ny_albers as r,
> >         cities_webMercator as p
> >     WHERE
> >         p.name = 'new_york'
> >     AND
> >         ST_Intersects(r.rast, ST_Transform(p.geom,102003))
> >     )  as foo;
> > I added the projection SRID:102003 using the following lines:
> > INSERT into
> >     spatial_ref_sys (
> >     srid,
> >     auth_name,
> >     auth_srid,
> >     srtext,
> >     proj4text
> > values (
> >      102003, -- I changed this line as it was originally 9102003 which
> did not satisfy
> > the constraints
> >      'esri',
> >      102003,
> > 'PROJCS["USA_Contiguous_Albers_Equal_Area_Conic",GEOGCS["GCS_North_A
> > merican_1983",DATUM["North_American_Datum_1983",SPHEROID["GRS_1980
> > ",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453
> > 292519943295]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["False_
> > Easting",0],PARAMETER["False_Northing",0],PARAMETER["longitude_of_center
> > 96],PARAMETER["Standard_Parallel_1",29.5],PARAMETER["Standard_Parallel_2
> > ",45.5],PARAMETER["latitude_of_center",37.5],UNIT["Meter",1],AUTHORITY["E
> > PSG","102003"]]',
> >      '+proj=aea +lat_1=29.5 +lat_2=45.5 +lat_0=37.5 +lon_0=-96 +x_0=0
> +y_0=0
> > +ellps=GRS80 +datum=NAD83 +units=m +no_defs ');
> > I had some problems when I tried to add this projection from
> > http://spatialreference.org/ref/esri/102003/postgis/
> > The names and values of srtext, and proj4text were reversed, and the SRID
> > seemed incorrect so I changed it. I don't know if this is related to my
> question
> > above, but I thought it worth mentioning. I did import the raster and
> polygon
> > using this SRID on the query that worked.
> > Thank you,
> > David
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120209/28bde01f/attachment.html>
