[postgis-users] [?? Probable Spam] Re: Trouble seeinglistingtables
Bistrais, Bob Bob.Bistrais at maine.gov
Mon Feb 13 14:30:55 PST 2012
I do not have a geometry_columns table in the mapfile, but here is my
connection strings in the map file:
LAYER
  NAME 'MAINE'
  DATA "the_geom from Metwp100Poly USING SRID=26919 USING Unique gid"
  CONNECTION "user=myuser  password=mypassword dbname=postgistest
host=localhost port=5432"
  CONNECTIONTYPE postgis
  PROCESSING "CLOSE_CONNECTION=DEFER"
  STATUS on
    Projection
            "init=epsg:26919"
    END
-Does this look correct?  I am still getting error messages.  Here is
the error from the debug log:
prepare_database(): Query error. Error declaring cursor: ERROR:
relation "metwp100poly" does not exist
LINE 1: ...lection(force_2d(the_geom)),'NDR'),gid::text from
Metwp100Po...
With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
Metwp100Poly WHERE the_geom && setSRID('BOX3D(134000
4692598.18523154,890900 5307401.81476846)'::BOX3D, 26919 )
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Francisco Salas Rosette
Sent: Monday, February 13, 2012 5:09 PM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] [?? Probable Spam] Re: Trouble
seeinglistingtables
Bob, this is one example for connection in mapserver with postgis , in
DATA section do you put the selection.
on the other hand, do you review in the geometry_columns table in public
scheme , if there exists you table?
the  geometry_columns table , describe projection, geometric columns ,
etc.
  LAYER
    CONNECTION "dbname=datosfg user=postgres password=postgres
host=localhost"
    CONNECTIONTYPE POSTGIS
    DATA "wkb_geometry from suelo USING SRID=4267001 USING Unique gid"
    METADATA
      "srid"              "4267001"
      "table_name"            " suelo"
      "cant_class_temat" "0"
      "field_list"    "gid, rugosidad, humedad, profundidad, suelo"
    END
    NAME "Suelos"
    STATUS ON
    TEMPLATE "ttt"
    TYPE POLYGON
    UNITS METERS
    CLASS
      NAME "Suelos"
      STYLE
        ANGLE 360
        COLOR 174 183 180
        OPACITY 100
        OUTLINECOLOR 35 80 65
        SYMBOL 0
      END
    END
  END
Francisco Salas
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de
Bistrais, Bob
Enviado el: lunes, 13 de febrero de 2012 04:47 p.m.
Para: PostGIS Users Discussion
Asunto: [?? Probable Spam] Re: [postgis-users] Trouble seeinglisting
tables
Hello Francisco,
I loaded the data using the PostGIS Shapefile and DBF Loader.  The table
has a column called the_geom.  I don't see any column for the SRS or
projection.
I made some progress- I forgot to put quotes on my table name, so my
select command should be:
SELECT * from "mytable";
-and that works correctly.
But, I am still not able to see my layer in MapServer.  I have posted to
the MapServer list as well, to see if anyone can help.  I get a
MapServer error that says:
ERROR: relation "mytable" does not exist...
Sent: Monday, February 13, 2012 4:44 PM
Subject: Re: [postgis-users] [!! SPAM] Trouble seeinglisting tables
Bob, do you review if there exists mytable in the geometry_columns
table?
How do you loaded this table?
Francisco salas
Bistrais, Bob
Enviado el: lunes, 13 de febrero de 2012 03:58 p.m.
Asunto: [!! SPAM] [postgis-users] Trouble seeinglisting tables
I am having trouble on a pretty basic level.  I loaded a couple
shapefiles into PostGIS.  I can see that they successfully loaded when I
use pgAdmin.  But when I go to command line, I have trouble.  I can do a
\d command and see the tables exist in the database.  But if I do a
select * from mytable; I get an errer, "relation "mytable" does not
exist.  What am I doing wrong here?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120213/1ca211a5/attachment.html>
