[postgis-users] advice for quicker display?
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Tue Feb 14 11:14:44 PST 2012
On 2/14/2012 1:57 PM, Bistrais, Bob wrote:
> As some of you already know, I’m a newbie to PostGIS and have just
> barely got a test PostGIS database up and running. So, my latest
> question is in regards to draw times. I created a statewide parcel layer
> from a shapefile. At statewide scale, when the application loads, the
> parcel data draws far slower than the original shapefile did. How can I
> tune this so that draw times are better?
If you are drawing all the data, it will always be slower than
shapefiles. The trick is to not draw more than is reasonable at a given
scale. So the answer is don't try to draw all the parcels for the whole
state. As you zoom in and need to only draw a subset of the parcels, you
will start to get speed advantages by using the spatial (GIST) indexes
in postgis.
create index mytable_the_geom_gidx on mytable using gist (the_geom);
-Steve W
