[postgis-users] extra function?
Bborie Park bkpark at ucdavis.edu
Wed Feb 22 10:59:18 PST 2012
Interesting.  Can you run the following and try again?
CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
exclude_nodata_value boolean)
	RETURNS summarystats
	AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
	LANGUAGE 'SQL' IMMUTABLE STRICT;
If that removes the HINT, I'll make the appropriate changes to the code.
-bborie
On 02/22/2012 10:48 AM, Stephen Crawford wrote:
> I only tried the casting because of the messages I get, on of which is:
> "function _st_summarystats($1, 1, $2, 1) is not unique"
> and
> "HINT: Could not choose best candidate function. You might need to add
> explicit type casts"
> Thanks,
> steve
> On 2/22/2012 1:41 PM, Bborie Park wrote:
>> Hey Steve,
>> _st_summarystats is an underlying function that isn't meant for use by
>> end-users. ST_SummaryStats is what you should be using.
>> The example query you provided shouldn't have any issues and shouldn't
>> be creating any of those messages. In your situation, you don't even
>> need the true::boolean.
>> -bborie
>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>> Should I have both _st_summarystats and st_summarystats in my database?
>>> I get messages like "function not unique" and "could not choose best
>>> candidate function" when doing this:
>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>> true::boolean) FROM spring_ms WHERE observation_date = '2012-02-20';
>>> I expected to get 187 records (one for each tile).
>>> Thanks,
>>> Steve
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
