[postgis-users] extra function?
Bborie Park bkpark at ucdavis.edu
Wed Feb 22 13:38:04 PST 2012
I'll do some experimenting when I'm done with my current work.
-bborie
On 02/22/2012 01:32 PM, Stephen Crawford wrote:
> Just tried it, same error and hint.
> -Steve
> On 2/22/2012 4:28 PM, Bborie Park wrote:
>> Steve,
>> I know enough to do my own testing and make the necessary changes.
>> Until I have the time to do so, the following should work.
>> CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
>> exclude_nodata_value boolean)
>> RETURNS summarystats
>> AS $$ SELECT _st_summarystats($1, 1, $2, 1.) $$
>> LANGUAGE 'SQL' IMMUTABLE STRICT;
>> -bborie
>> On 02/22/2012 12:16 PM, Stephen Crawford wrote:
>>> Tried running it and get this:
>>> "ERROR: function _st_summarystats(raster, integer, boolean, integer) is
>>> not unique
>>> LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
>>> HINT: Could not choose best candidate function. You might need to add
>>> explicit type casts"
>>> -Steve
>>> On 2/22/2012 1:59 PM, Bborie Park wrote:
>>>> Interesting. Can you run the following and try again?
>>>> If that removes the HINT, I'll make the appropriate changes to the
>>>> code.
>>>> -bborie
>>>> On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>>>>> I only tried the casting because of the messages I get, on of which
>>>>> is:
>>>>> "function _st_summarystats($1, 1, $2, 1) is not unique"
>>>>> and
>>>>> "HINT: Could not choose best candidate function. You might need to add
>>>>> Thanks,
>>>>> steve
>>>>> On 2/22/2012 1:41 PM, Bborie Park wrote:
>>>>>> Hey Steve,
>>>>>> _st_summarystats is an underlying function that isn't meant for
>>>>>> use by
>>>>>> end-users. ST_SummaryStats is what you should be using.
>>>>>> The example query you provided shouldn't have any issues and
>>>>>> shouldn't
>>>>>> be creating any of those messages. In your situation, you don't even
>>>>>> need the true::boolean.
>>>>>> -bborie
>>>>>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>>>>>> Should I have both _st_summarystats and st_summarystats in my
>>>>>>> database?
>>>>>>> I get messages like "function not unique" and "could not choose best
>>>>>>> candidate function" when doing this:
>>>>>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>>>>>> true::boolean) FROM spring_ms WHERE observation_date = '2012-02-20';
>>>>>>> I expected to get 187 records (one for each tile).
>>>>>>> Thanks,
>>>>>>> Steve
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
