[postgis-users] extra function?
Bborie Park bkpark at ucdavis.edu
Wed Feb 22 13:48:32 PST 2012
Good point.  I didn't think about duplicative function declarations,
though that shouldn't happen as the function signatures haven't changed
in a long time.
-bborie
On 02/22/2012 01:39 PM, John Callahan wrote:
> Steve,
> I had a similar issue.  If you look at your list of functions (say through
> pgAdmin), you'll probably see multiple instances of that function.  If the
> same function is listed more than once, with the same number and type of
> arguments, then it will (I think?) report as not unique.  In that case, I
> manually deleted the duplicate functions, and then added them back.  To add
> them back, look inside the rt_postgis.sql (or postgis.sql) file than comes
> with the distribution (I'm using alpha5).  you'll see all of the functions
> in there.  Just cut and paste the necessary CREATE OR REPLACE statements
> for your functions into the Query Tool or psql console window.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> On Wed, Feb 22, 2012 at 4:28 PM, Bborie Park<bkpark at ucdavis.edu>  wrote:
>> Steve,
>> I know enough to do my own testing and make the necessary changes. Until I
>> have the time to do so, the following should work.
>> CREATE OR REPLACE FUNCTION st_summarystats(rast raster,
>> exclude_nodata_value boolean)
>> RETURNS summarystats
>> AS $$ SELECT _st_summarystats($1, 1, $2, 1.) $$
>> LANGUAGE 'SQL' IMMUTABLE STRICT;
>> -bborie
>> On 02/22/2012 12:16 PM, Stephen Crawford wrote:
>>> Tried running it and get this:
>>> "ERROR: function _st_summarystats(raster, integer, boolean, integer) is
>>> not unique
>>> LINE 3: AS $$ SELECT _st_summarystats($1, 1::int, $2, 1) $$
>>> HINT: Could not choose best candidate function. You might need to add
>>> explicit type casts"
>>> -Steve
>>> On 2/22/2012 1:59 PM, Bborie Park wrote:
>>>> Interesting. Can you run the following and try again?
>>>> If that removes the HINT, I'll make the appropriate changes to the code.
>>>> -bborie
>>>> On 02/22/2012 10:48 AM, Stephen Crawford wrote:
>>>>> I only tried the casting because of the messages I get, on of which is:
>>>>> "function _st_summarystats($1, 1, $2, 1) is not unique"
>>>>> and
>>>>> "HINT: Could not choose best candidate function. You might need to add
>>>>> Thanks,
>>>>> steve
>>>>> On 2/22/2012 1:41 PM, Bborie Park wrote:
>>>>>> Hey Steve,
>>>>>> _st_summarystats is an underlying function that isn't meant for use by
>>>>>> end-users. ST_SummaryStats is what you should be using.
>>>>>> The example query you provided shouldn't have any issues and shouldn't
>>>>>> be creating any of those messages. In your situation, you don't even
>>>>>> need the true::boolean.
>>>>>> -bborie
>>>>>> On 02/22/2012 10:34 AM, Stephen Crawford wrote:
>>>>>>> Should I have both _st_summarystats and st_summarystats in my
>>>>>>> database?
>>>>>>> I get messages like "function not unique" and "could not choose best
>>>>>>> candidate function" when doing this:
>>>>>>> SELECT rid, observation_date, ST_SummaryStats(rast::raster,
>>>>>>> true::boolean) FROM spring_ms WHERE observation_date = '2012-02-20';
>>>>>>> I expected to get 187 records (one for each tile).
>>>>>>> Thanks,
>>>>>>> Steve
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
>> ______________________________**_________________
>> postgis-users mailing list
>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
Bborie Park
Programmer
UC Davis
530-752-8380
