[postgis-users] topology example
Sandro Santilli strk at keybit.net
Fri Feb 24 00:10:30 PST 2012
On Fri, Feb 24, 2012 at 07:34:54AM +0100, Denis Rouzaud wrote:
> Hi Sandro,
> Thanks again.
> I have a fresh installed for 2 days now.
> Postgis 2.0 a6 (it is a 7 now)
> Geos 3.3.2
> Is this ok?
Should be, yes.
> I did not do anything with topology_upgrade.sql, there is nothing
> written in the installation doc.
That's a bug in the documentation, could you file it on
http://trac.osgeo.org please ?
> What should I do with it?
The same you do with postgis_upgrade.sql everytime you do upgrade
from one version to another... load it.
> Would you perform a loop to update the topogeom field, so one entry at once?
A loop would indeed be preferrable. I saw a noticable speedup
when looping from outside the database.
> Thanks a lot for your valuable help!
Thank you for your feedback, keep me posted ! :)
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
