[postgis-users] Rv: Postgis for Postgres 64 bits
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Fri Feb 24 10:18:08 PST 2012
Discussions on 32 bit vs 64 bit Postgresql:
http://archives.postgresql.org/pgsql-performance/2004-11/msg00201.php
http://postgresql.1045698.n5.nabble.com/64-bit-vs-32-bit-performance-backwards-td2057238.html
See document on 5 steps to postgresql performance by Josh Berkus:
http://www.pgexperts.com/document.html?id=36
"64 bit performance can be 5-20% faster"
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
Andy Colson <andy at squeakycode.net>
Sent by: postgis-users-bounces at postgis.refractions.net
02/04/2012 02:52 PM
Please respond to
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
To
cc
Subject
Re: [postgis-users] Rv:  Postgis for Postgres 64 bits
On 02/04/2012 01:14 PM, Darrel Maddy wrote:
> Dear Regina,
> I would be happy to contribute $100 into any fund which secures a 64-bit
windows build of PostGIS2 -especially as I am about to install it on a
machine with 64Gb RAM :)
> Count now at 1 ?
> Thanks
> Darrel
> http://www.ncl.ac.uk/gps/staff/profile/darrel.maddy#tab_profile
I really wonder if its faster.  I'd bet not.  If you consider the
architecture, I'd bet, for all but the very largest of datasets, 32 bit PG
running on top 64 bit os is faster.
Consider: you want the os disk cache to be as large as possible.  You want
a bunch of shared mem and I'd bet around 2 gig would be a sweet spot. More
shared mem wouldn't necessarily be a benefit. (There are upper bounds
recommended for shared_buffers, especially on windows).
PG spawns a separate client for each connection, so each one of them could
access up to 2 gig.  (so things like work_mem could be large).
And last, 32bit programs are faster because they move less data around
(32bit pointers instead of 64bit).
Taken all together PostMaster + (clients * postgres.exe) + os cache could
easly be more than 2 gig using 32 bit PG on 64 bit windows.
The only benefit of using 64bit PG would be a larger shared mem.  The
online manual says: "The useful range for shared_buffers on Windows
systems is generally from 64MB to 512MB"
http://www.postgresql.org/docs/9.1/static/runtime-config-resource.html
The best use of ram, is as a disk cache, which 64 bit windows should use
as much as possible (well, I assume).  After that there is nothing in
Postgres (Per Client) that is going to run faster with more than 2 gig of
ram.
Has anyone ever done any benchmarks?
-Andy
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120224/8bc47ad3/attachment.html>
