[postgis-users] GISGRAPHY setup issue
Ing. Ramon Resendiz rresendiz at globaltrack.com.mx
Mon Jan 2 12:38:15 PST 2012
Hi all,
I’ve tried to install the GISGRAPHY to integrated it with OPENGTS, i’ve
successfully installed OPENGTS but when I tried to configure the POSGTIS
database to create the postgis function there is an error, that I couldn’t
found information about it, that why I’m recurring to you.
The issues is the following:
# create the database
psql -U YOURUSER  -h YOURIP -c  "CREATE DATABASE gisgraphy ENCODING =
'UTF8';" à OK
#create language
createlang -U YOURUSER -h YOURIP plpgsql gisgraphy à OK
Descripción: Descripción: cid:image001.png at 01CCC6F0.1A2B5580
#create postgis function
psql -U USER -h 127.0.0.1 -d gisgraphy -f
/usr/share/pgsql/contrib/postgis-1.5/postgis.sql à ERROR
There is some function that create without any problem until the next error
message appear:
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:2024: ERROR:  language
"plpgsql" does not exist
HINT:  Use CREATE LANGUAGE to load the language into the database.
Descripción: Descripción: cid:image002.png at 01CCC6F0.1A2B5580
Even when i tried to import the file spatial_ref_sys.sql there is an error,
I try to figure out due the postgis.sql could not was imported correctly.
/usr/share/postgresql-YOURPOSTGRESVERSION-postgis/spatial_ref_sys.sql
Best regards,
RR
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120102/f1c565a4/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120102/f1c565a4/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120102/f1c565a4/attachment-0001.png>
