[postgis-users] shp2pgsql - how to continue when error occurs
Lauri Kajan lauri.kajan at gmail.com
Tue Jan 3 02:46:43 PST 2012
Thanks Imran,
That was also in my mind, but thought I could have less steps to
complete the import.
-Lauri
On Tue, Jan 3, 2012 at 11:50 AM, Nithya lakshmi
<lakshmi.nithya18 at gmail.com> wrote:
> how to use Rtree in postgis
> On 1/3/12, Muhammad Imran <imranserver at yahoo.com> wrote:
>> Hi Lauri,
>> 1- Disable or remove unique key (UK) on table.
>> 2- Import data using shp2pgsql
>> 3- remove duplicate rows using SQL
>> DELETE
>> FROM  sometable
>> WHERE         someuniquekey NOT IN
>>       (SELECT         MAX(dup.someuniquekey)
>>         FROM                  sometable As dup
>>         GROUP BY      dup.dupcolumn1, dup.dupcolumn2, dup.dupcolum3)
>> (http://www.postgresonline.com/journal/archives/22-Deleting-Duplicate-Records-in-a-Table.html)
>> 4- Enforce UK
>> -Imran
>> --- On Tue, 1/3/12, Lauri Kajan <lauri.kajan at gmail.com> wrote:
>>> From: Lauri Kajan <lauri.kajan at gmail.com>
>>> Subject: [postgis-users] shp2pgsql - how to continue when error occurs
>>> To: postgis-users at postgis.refractions.net
>>> Date: Tuesday, January 3, 2012, 1:18 PM
>>> Hi all,
>>> I'm trying to merge multiple shapefiles to postgis table. I
>>> know that
>>> there is some duplicates in different files.
>>> I thought that I could just check duplicatiness when
>>> loading shapes
>>> with shp2pgsql.
>>> So I first created an empty table and added a unique
>>> constraint to the
>>> field that I know to be unique with non duplicate records.
>>> But now when shp2pgsql tries to insert first duplicate
>>> record and
>>> error occurs it stops and won't load any records.
>>> Is there a way to continue when "key already exists" -error
>>> occurs?
>>> I read that in shp2pgsql that comes with 2.0 it has -e
>>> parameter that
>>> loads each record invidually. Is this the only way to go?
>>> Don't like
>>> that cause I have 13GB shape files. And I would like to use
>>> Dump
>>> dormat.
>>> Thanks
>>> -Lauri
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
