[postgis-users] Insert a point value : ST_GeometryFromText unknown function [resolved]
efusien jeremie.bryon at efusia.net
Tue Jan 3 13:54:17 PST 2012
It works fine !
I did:
$ sudo su postgres
$ psql -d test -f /usr/share/postgresql/9.1/contrib/postgis-1.5/postgis.sql
-v ON_ERROR_STOP=1
$ psql -d test -f
/usr/share/postgresql/9.1/contrib/postgis-1.5/spatial_ref_sys.sql
$ psql -d test -f /usr/share/postgresql/9.1/contrib/postgis_comments.sql
Other problems appears now, but I can continue. Thank's a lot.
Sandro Santilli wrote:
> On Tue, Jan 03, 2012 at 01:22:11PM -0800, efusien wrote:
>> $ sudo psql -d test -f
>> /usr/share/postgresql/9.1/contrib/postgis-1.5/postgis.sql -v
>> ON_ERROR_STOP=1
>> => SET
>> BEGIN
>> psql:/usr/share/postgresql/9.1/contrib/postgis-1.5/postgis.sql:59: ERROR:
>> permission denied for language c
>> ...fail
>> I see on other websites that I have to be logged with root. But I
>> allready
>> use "sudo" (Ubuntu). What's wrong ? Any idea ?
> You have to be a database "superuser".
> It's usually user "postgres". Try:
>  sudo su postgres -c psql -d test \
>   -f /usr/share/postgresql/9.1/contrib/postgis-1.5/postgis.sql \
>   -v ON_ERROR_STOP=1
> --strk;
>   ,------o-.
>   |   __/  |    Thank you for PostGIS-2.0 Topology !
>   |  / 2.0 |    http://www.pledgebank.com/postgistopology
>   `-o------'
> postgis-users mailing list
View this message in context: http://old.nabble.com/Insert-a-point-value-%3A-ST_GeometryFromText-unknown-function-tp33073860p33075357.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
