[postgis-users] GISGRAPHY setup issue
Ing. Ramon Resendiz
rresendiz at globaltrack.com.mx
Tue Jan 3 17:07:54 PST 2012
OK ive found the problem here the language plpgsql i dont know why but is
empty, so must create the function plpgsql before to load functions from the
file plpgsql.sql.
Here are the steps:
1. Find the file plpgsql.so
[root at gtlabserver01 pgsql]# find / -name plpgsql.so -print
/usr/lib64/pgsql/plpgsql.so
2. Install the handler and the language as function called plpgsql,
then execute the following command:
(CREATE FUNCTION plpgsql_call_handler () RETURNS OPAQUE AS
'change_this_path_by_the_path_found_in_the_step_1' LANGUAGE 'C'; CREATE
LANGUAGE 'plpgsql' HANDLER plpgsql_call_handler LANCOMPILER 'PL/pgSQL';)
3. In my case the command look like this:
'/usr/lib64/pgsql/plpgsql.so' LANGUAGE 'C'; CREATE LANGUAGE 'plpgsql'
4. After the command runs may the following message could be appear:
[root at gtlabserver01 pgsql]# psql -U postgres -h 127.0.0.1 -c "CREATE
HANDLER plpgsql_call_handler LANCOMPILER 'PL/pgSQL';"
NOTICE: using pg_pltemplate information instead of CREATE LANGUAGE
parameters
CREATE LANGUAGE
5. Then try again run the script that cause the error and now will be
completed correctly, like in my case.
6. I hope this will help to further persons in the future.
... again, I'm sorry. It was not my intention to abuse this forum.
Best regards,
RR
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] En nombre de Paragon
Corporation
Enviado el: lunes, 02 de enero de 2012 09:41 p.m.
Para: 'PostGIS Users Discussion'
Asunto: Re: [postgis-users] GISGRAPHY setup issue
What you have looks right, but perhaps the account you are using to install
postgis.sql doesn't have rights to language or the port it default to is
different.
You could try doing using:
psql -U USER -h 127.0.0.1 -d gisgraphy -c "CREATE LANGUAGE plpgsql;"
In theory you should have same issue but you might get a different message.
Which version of PostgreSQL are you using?
You might also try postgresql general as I don't think this is a PostGIS
specific issue.
Hope that helps,
Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ing.
Ramon Resendiz
Sent: Monday, January 02, 2012 3:38 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] GISGRAPHY setup issue
Hi all,
Ive tried to install the GISGRAPHY to integrated it with OPENGTS, ive
successfully installed OPENGTS but when I tried to configure the POSGTIS
database to create the postgis function there is an error, that I couldnt
found information about it, that why Im recurring to you.
The issues is the following:
# create the database
psql -U YOURUSER -h YOURIP -c "CREATE DATABASE gisgraphy ENCODING =
'UTF8';" à OK
#create language
createlang -U YOURUSER -h YOURIP plpgsql gisgraphy à OK
Descripción: Descripción: cid:image001.png at 01CCC6F0.1A2B5580
#create postgis function
psql -U USER -h 127.0.0.1 -d gisgraphy -f
/usr/share/pgsql/contrib/postgis-1.5/postgis.sql à ERROR
There is some function that create without any problem until the next error
message appear:
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:2024: ERROR: language
"plpgsql" does not exist
HINT: Use CREATE LANGUAGE to load the language into the database.
Descripción: Descripción: cid:image002.png at 01CCC6F0.1A2B5580
Even when i tried to import the file spatial_ref_sys.sql there is an error,
I try to figure out due the postgis.sql could not was imported correctly.
/usr/share/postgresql-YOURPOSTGRESVERSION-postgis/spatial_ref_sys.sql
Best regards,
RR
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120103/12d3ad4a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120103/12d3ad4a/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120103/12d3ad4a/attachment-0001.png>
