[postgis-users] Postgis installation on sles 11 sp1
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Wed Jan 4 08:05:59 PST 2012
Hi Otto,
I need postgis to work with at least postgres v9.0
regards,
Steve
Otto Dassau <dassau at gbd-consult.de>@postgis.refractions.net
Envoyé par : postgis-users-bounces at postgis.refractions.net
2012-01-04 09:49
Veuillez répondre à
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
A
cc
Objet
Re: [postgis-users] Postgis installation on sles 11 sp1
Hi Steve,
I recently (3 weeks ago) updated the postgis package for SLES 11 on
Application:Geo to version 1.5.3. They built without any problems on SLES
11 and I think (didn't test), that they also work with the standard
postgresql packages provided with SLES 11, but that's not version 9.1.2.
Have you tried to use the standard postgres from SLES 11? I think it is
8.1.x?
Regards
Otto
Am Wed, 4 Jan 2012 09:33:29 -0500
schrieb Steve.Toutant at inspq.qc.ca:
> Hi,
> I still can't make postgis work on sles 11 sp1
> I successfully installed postgres 9.1.2-64.1 from this repository
http://download.opensuse.org/repositories/server:/database:/postgresql/SLE_11_SP1
> Then I installed postgis from this repo of sles11 (not sp1)
http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/SLE_11
> (also tried with this one
> http://download.opensuse.org/repositories/Application:/Geo/SLE_11)
> Everything went well but I when I tried to enable postgis running
> postgis.sql, I got this error
> psql:/usr/share/postgresql/contrib/postgis-1.5/postgis.sql:59: ERREUR:
n'a
> pas pu charger la bibliothèque « /usr/lib64/postgresql/postgis-1.5.so »
> /usr/lib64/postgresql/postgis-1.5.so: undefined symbol:
> DirectFunctionCall4
> I also tried to compile postgis but I got this error
/usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
> /usr/lib64/libxml2.a(parser.o): relocation R_X86_64_32S against
> `.rodata.str1.1' can not be used when making a shared object; recompile
> with -fPIC
> /usr/lib64/libxml2.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> Anyone successfully installed postgis on sles 11 SP1?
> Any help or suggestions?
> Thanks for your help
> Steve
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120104/7138ccee/attachment.html>
