[postgis-users] Postgis installation on sles 11 sp1
Steve.Toutant at inspq.qc.ca
Wed Jan 4 11:30:51 PST 2012
If I install postgres 9 using postgresql-libs v8.3 from sles 11
distribution I got this error when I create a database
createdb: symbol lookup error: createdb: undefined symbol:
PQconnectdbParams
Thanks for your support
Regards
steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
Tél.: 418 646-6777 poste 30015
Téléc.: 418 644-4593
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
http://www.monclimatmasante.qc.ca
Pour me rejoindre par courrier
Service de l'infrastructure et du réseau
Direction des technologies de l'information
Ministère de la Sécurité Publique
2525 boul. Laurier, 2è étage
Tour Laurentides
Québec, G1V 2L2
Otto Dassau <dassau at gbd-consult.de>@postgis.refractions.net
Envoyé par : postgis-users-bounces at postgis.refractions.net
2012-01-04 14:15
Veuillez répondre à
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
A
cc
Objet
Re: [postgis-users] Postgis installation on sles 11 sp1
I have to look at it tomorrow. There is also a problem with postgis
packaging I have to fix. I write again, when it is working.
Regards
Otto
Am Wed, 4 Jan 2012 14:01:44 -0500
schrieb Steve.Toutant at inspq.qc.ca:
> Thanks Otto,
> I saw that these packages are now available in sles11_sp1. quick...!!
> But the repo contains package postgresql-libs-8.3.9-0.1.1.x86_64
> Should it be 9.1.2-64.1 as per postgresql-server?
> many thanks again
> Steve
> Tour Laurentides
> Québec, G1V 2L2
> 2012-01-04 13:09
> Veuillez répondre à
> A
> cc
> Objet
> Hi Steve,
> ok, then the Application:Geo packages won't work for you, because they
> don't provide postgresql 9 for SLE_11.
> I updated the Application:Geo:Postgres9PostGIS1 repository. It now
> provides
> postgres 9.1.2 and postgres 1.5.3, also for SLE_11. Please try, if that
> works for you. The packages will be available soon, also for SLE_11_SP1,
I
> guess.
http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/
> Regards
> Otto
> Am Wed, 4 Jan 2012 11:05:59 -0500
> > Hi Otto,
> > I need postgis to work with at least postgres v9.0
> > regards,
> > Steve
> > 2012-01-04 09:49
> > Veuillez répondre à
> > A
> > cc
> > Objet
> > Hi Steve,
> > I recently (3 weeks ago) updated the postgis package for SLES 11 on
> > Application:Geo to version 1.5.3. They built without any problems on
> SLES
> > 11 and I think (didn't test), that they also work with the standard
> > postgresql packages provided with SLES 11, but that's not version
9.1.2.
> > Have you tried to use the standard postgres from SLES 11? I think it
is
> > 8.1.x?
> > Regards
> > Otto
> > Am Wed, 4 Jan 2012 09:33:29 -0500
> > > Hi,
> > > I still can't make postgis work on sles 11 sp1
> > > I successfully installed postgres 9.1.2-64.1 from this repository
http://download.opensuse.org/repositories/server:/database:/postgresql/SLE_11_SP1
> > > Then I installed postgis from this repo of sles11 (not sp1)
http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/SLE_11
> > > (also tried with this one
> > > http://download.opensuse.org/repositories/Application:/Geo/SLE_11)
> > > Everything went well but I when I tried to enable postgis running
> > > postgis.sql, I got this error
> > > psql:/usr/share/postgresql/contrib/postgis-1.5/postgis.sql:59:
ERREUR:
> > n'a
> > > pas pu charger la bibliothèque «
/usr/lib64/postgresql/postgis-1.5.so
> > > /usr/lib64/postgresql/postgis-1.5.so: undefined symbol:
> > > DirectFunctionCall4
> > > I also tried to compile postgis but I got this error
/usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
> > > /usr/lib64/libxml2.a(parser.o): relocation R_X86_64_32S against
> > > `.rodata.str1.1' can not be used when making a shared object;
> recompile
> > > with -fPIC
> > > /usr/lib64/libxml2.a: could not read symbols: Bad value
> > > collect2: ld returned 1 exit status
> > > Anyone successfully installed postgis on sles 11 SP1?
> > > Any help or suggestions?
> > > Thanks for your help
> > > Steve
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120104/580c4b98/attachment.html>
