[postgis-users] Postgis installation on sles 11 sp1
Otto Dassau dassau at gbd-consult.de
Wed Jan 4 11:43:17 PST 2012
Hi Steve,
just another note for now. The Application:Geo:Postgres9PostGIS1 repo does
not contain postgresql-libs-8.3.9, see:
http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/
It is probably part of SLE_11. I guess, you don't need to install that
package. All libs are included in the postgresql-server package, I guess.
Regards
Otto
Am Wed, 4 Jan 2012 20:15:07 +0100
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> I have to look at it tomorrow. There is also a problem with postgis
> packaging I have to fix. I write again, when it is working.
> Regards
>  Otto
> Am Wed, 4 Jan 2012 14:01:44 -0500
> schrieb Steve.Toutant at inspq.qc.ca:
> > Thanks Otto,
> > I saw that these packages are now available in sles11_sp1. quick...!!
> > But the repo contains package postgresql-libs-8.3.9-0.1.1.x86_64
> > Should it be 9.1.2-64.1 as per postgresql-server?
> > many thanks again
> > Steve
> > Steve Toutant, M. Sc.
> > Analyste en géomatique
> > Secteur environnement
> > Direction de la santé environnementale et de la toxicologie
> > Institut national de santé publique du Québec
> > Tél.: 418 646-6777 poste 30015
> > Téléc.: 418 644-4593
> > steve.toutant at inspq.qc.ca
> > http://www.inspq.qc.ca
> > http://www.monclimatmasante.qc.ca
> > Pour me rejoindre par courrier
> > Service de l'infrastructure et du réseau
> > Direction des technologies de l'information
> > Ministère de la Sécurité Publique
> > 2525 boul. Laurier, 2è étage
> > Tour Laurentides
> > Québec, G1V 2L2
> > Otto Dassau <dassau at gbd-consult.de>@postgis.refractions.net
> > Envoyé par : postgis-users-bounces at postgis.refractions.net
> > 2012-01-04 13:09
> > Veuillez répondre à
> > PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> > A
> > cc
> > Objet
> > Re: [postgis-users] Postgis installation on sles 11 sp1
> > Hi Steve,
> > ok, then the Application:Geo packages won't work for you, because they
> > don't provide postgresql 9 for SLE_11.
> > I updated the Application:Geo:Postgres9PostGIS1 repository. It now
> > provides
> > postgres 9.1.2 and postgres 1.5.3, also for SLE_11. Please try, if that
> > works for you. The packages will be available soon, also for SLE_11_SP1,
> > I guess.
> > Regards
> > Otto
> > Am Wed, 4 Jan 2012 11:05:59 -0500
> > > Hi Otto,
> > > I need postgis to work with at least postgres v9.0
> > > regards,
> > > Steve
> > > 2012-01-04 09:49
> > > Veuillez répondre à
> > > A
> > > cc
> > > Objet
> > > Hi Steve,
> > > I recently (3 weeks ago) updated the postgis package for SLES 11 on
> > > Application:Geo to version 1.5.3. They built without any problems on
> > SLES
> > > 11 and I think (didn't test), that they also work with the standard
> > > postgresql packages provided with SLES 11, but that's not version
> > > 9.1.2.
> > > Have you tried to use the standard postgres from SLES 11? I think it is
> > > 8.1.x?
> > > Regards
> > > Otto
> > > Am Wed, 4 Jan 2012 09:33:29 -0500
> > > > Hi,
> > > > I still can't make postgis work on sles 11 sp1
> > > > I successfully installed postgres 9.1.2-64.1 from this repository
> > http://download.opensuse.org/repositories/server:/database:/postgresql/SLE_11_SP1
> > > > Then I installed postgis from this repo of sles11 (not sp1)
> > http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/SLE_11
> > > > (also tried with this one
> > > > http://download.opensuse.org/repositories/Application:/Geo/SLE_11)
> > > > Everything went well but I when I tried to enable postgis running
> > > > postgis.sql, I got this error
> > > > psql:/usr/share/postgresql/contrib/postgis-1.5/postgis.sql:59:
> > > > ERREUR:
> > > n'a
> > > > pas pu charger la bibliothèque
> > > > « /usr/lib64/postgresql/postgis-1.5.so
> > > > /usr/lib64/postgresql/postgis-1.5.so: undefined symbol:
> > > > DirectFunctionCall4
> > > > I also tried to compile postgis but I got this error
> > /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
> > > > /usr/lib64/libxml2.a(parser.o): relocation R_X86_64_32S against
> > > > `.rodata.str1.1' can not be used when making a shared object;
> > recompile
> > > > with -fPIC
> > > > /usr/lib64/libxml2.a: could not read symbols: Bad value
> > > > collect2: ld returned 1 exit status
> > > > Anyone successfully installed postgis on sles 11 SP1?
> > > > Any help or suggestions?
> > > > Thanks for your help
> > > > Steve
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
