[postgis-users] Custom Projection
Birgit Laggner birgit.laggner at vti.bund.de
Sun Jan 8 23:59:08 PST 2012
Hallo Sean,
I tested it myself and this is because of the export function you are
using. If I am using pgsql2shp, this results in the following prj:
GEOGCS["Geographic Coordinate System",DATUM["WGS84",SPHEROID["WGS
84",6378137,298.257223560493,AUTHORITY["Custom","0"]],AUTHORITY["Custom","0"]],PRIMEM["Greenwich",0,AUTHORITY["Custom","0"]],UNIT["degree",0.0174532925199433,AUTHORITY["Custom","0"]],AUTHORITY[""Custom","0"]]
And this would be exactly as you want (the custom authority entries you
may spare probably...). I don't know, if there is a way to tell QGIS to
export exactly the coordinate system from the data origin.
Regards,
Birgit.
Am 06.01.2012 18:42, schrieb Sean Christopher Conway:
> Hello, thank you for your reply. Yes, essentially I have done this
> exact SQL, but when I export it using quantum gis or FME, i get the
> following projection parameters
> Geographic Coordinate System:    GCS_WGS_1984
> Datum:     D_WGS_1984
> Prime Meridian:     Greenwich
> Angular Unit:     Degree
> whereas, I would like these parameters:
> Geographic Coordinate System:    Geographic Coordinate System
> Datum:     WGS84
> Angular Unit:     degree
> We need it to be like this and are using the following projection to
> create it:
> System",DATUM["WGS84",SPHEROID["WGS84",6378137,298.257223560493],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120109/e095d933/attachment.html>
