[postgis-users] Re : IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Vince Lotito
vince at vvl.com
Sat Jan 14 11:01:22 PST 2012
Just-In-Time debugging launches Visual Studio automatically when an exception or crash occurs in an application running outside Visual Studio. This enables you to test your application when Visual Studio is not running and begin debugging with Visual Studio when a problem occurs. This does not apply to the Express edition of Visual Studio. Are you running ifc2pg.exe under the Visual Studio Express debugger? If so, then you should be able to debug the exception.
V
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of jrmrolland at aol.com
Sent: Saturday, January 14, 2012 1:14 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re : IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Chris,
I am busy for the next three week, you need Framework 4.0 for ifc2pg.
I am looking for this problem as soon as possible.
best regards,
Jerome
-----E-mail d'origine-----
De : Chris English <sglish at hotmail.com<mailto:sglish at hotmail.com>>
A: postgis_users <postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net>>
Envoyé le : Samedi, 14 Janvier 2012 18:26
Sujet : Re: [postgis-users] IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Jerome,
Under Visual Studios Express 2010 - An unhandled win32 exception occured in ifc2pg.exe[3560].
Just-In_Time debugging this exception failed: No installed debugger has Just-In-Time debugging enabled.
VS Express doesn't (seem to) have JIT debugging capability. Does ifc2pg require VS Pro or is there
some work around for Express?
Thanks,
Chris
> Date: Thu, 12 Jan 2012 07:27:54 -0800
> From: jrmrolland at aol.com<mailto:jrmrolland at aol.com>
> To: postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net>
> Subject: [postgis-users] IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
> Hello,
> I have just set up on my blog at the following address
> http://ageoguy.blogspot.com/2012/01/ifc2pg-3d-industry-foundation-classes.html
> A GeoSpatial World
> the third part of a tutorial which presents IFC2PG a tool under development
> which makes it possible to export the objects of a file IFC towards PostGIS.
> http://postgis.17.n6.nabble.com/file/n3665545/ifc2pg_splashscreen3.gif
> This 3rd part inserts to us in the world of the third dimension under
> PostGIS 2.0,
> the objects imported in the database will be it in 3D.
> Regards,
> Jérôme
> View this message in context: http://postgis.17.n6.nabble.com/IFC2PG-3D-Industry-Foundation-Classes-to-PostGIS-3rd-Part-tp3665545p3665545.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120114/0a14c236/attachment.html>
